S13 Ka Vs S14 Ka
which block is better... i was talking to a guy that works at horsepowerfreaks.com and he told me that the s13 motors are stronger (better pistons and rods) than the s14 motors under boost. He also said that the s14 motors have a tendancy to blow at any boost level... some at 8 some a 15?
From my knowledge of KA's, ive always heard that a KA was a KA... but this guy says that approx after the 94 year, Nissan ditched the stronger S13 bottom end for a "cheaper" & weaker bottom end which they put in the s14's. Can anyone give me more insite to what this guy is saying. I plan on boosting my engine to about 8lbs but i don't have the extra ~1k to build my bottom end. Im afraid that if i boost my engine it will blow and that will suk ass b/c im on my third motor and im tired of swapping them in and out! |
![]() Join Date: Dec 2002
I can tell you that the sky is green. Do you believe me?
KA is a KA. There is no change in bottom end parts from what all the research has shown. Motors blow becasue they detonate, some at 8psi and some at 15psi. It's called tuning.
![]() Join Date: Sep 2003
Maybe he was talking about the compression ratio. The ratio is higher on the S14 motors, thats why the cams are different and you can get power swapping cams. If you're gonna boost, use the S13 motor since you're not gonna re-build the bottom end. That way, you get the lower compression ratio and its safer to boost.
In search of a Zenki S14 right side (passenger) fender and straight hood that are rust free. |
#4 | |
Autox Technician
![]() Join Date: Dec 2001
Between S13 and S14 KA24DE's, the compression ratio is the same.
![]() Join Date: Aug 2003
9.2 to 1?
I wonder if the same thing would apply to the Altima talking about Block rigidty (sp). Quote:
U13 and S13 zilvia members are friendly
![]() Join Date: Mar 2003
the "blowing engines" part is probably attributed to the S14s running a leaner mixture. This was used to get rid of the air injection in S13s. A smog thing.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing. |
thought the later S13 would probably run obdII emission, though at WOT it should run extremely rich, well, at least these were applied to the later 1st gen Altimas...
#8 | |
9.5:1 CR on ALL DE motors, the SOHCs ran lower compression. The cams have a different profile because the S13s used the SCVs to build lowend torque, while the S14s don't have them. Has nothing to do with CR. S14s don't run a leaner mixture, and the AIV system on the S13 has no effect on A/Fs, it's strictly used for emissions, the ECU doesn't pull timing or increase the fuel map if it's removed.
#10 | |
From my understanding, the S13 DE motors run a 8.6:1 compression, thats why the longer duration cams were used. The S14's run a 9:1 compression ratio using the shorter duration cams. Why do you think you can get power from S13 cams in the S14 engines. Anyone else have information on this? EDIT: Hey, bright one, check this out. Apparently I'm right. The '91 DE I lower than the '95 DE. Heres your proof: '89 Motor: http://www.socal240sx.org/faq/1989.html '91 Motor: http://www.socal240sx.org/faq/1991.html '95 Motor: http://www.socal240sx.org/faq/1995.html Theres your proof. Idiot.
In search of a Zenki S14 right side (passenger) fender and straight hood that are rust free. Last edited by Pacman; 11-18-2004 at 07:08 PM.. |
#11 | |
Inactive Admin
![]() Join Date: Mar 2002
I hate you too...
![]() Join Date: Jul 2001
/sigh.
Advanceautoparts.com. An accurate and unbiased site. 1995 piston part #: AE Clevite Engine Parts 2242985 PISTON SET Retail Price: $61.54 1991 piston part #: AE Clevite Engine Parts 2242985 PISTON SET Retail Price: $61.54 Looks the same to me. Russ knows his shit, unlike you. So just calm down. People have talked about the possibility of 8.6:1 cr running into the '91 during the very beginning, but I've seen no proof. -Jeff
Whatup? |
#14 | |
S13 DEs use the SCVs to help produce lower end torque, staying slightly closed until 4k rpm, therefore the cams have a longer duration for more power up top. The S14 motors opted not to use the SCVs, so a cam change gives the same power throughout the revband without sacrificing midrange response. S13 cams in an S14 motor make more power because they lack those SCVs. Socal's page is incorrect, sorry. I've got a copy of an 89, 92, 96, and 98 FSM right here at my desk. 89 SOHCs ran 8.6:1, 90 models were upped to 9.0:1 (IIRC), and ALL DOHC motors, 91-98, including the 93-01 Altima, ran 9.5:1. Nissan OE part numbers on pistons are the same from 8/90 all the way until 11/00. Do yourself a favor and research thoroughly a proven resource first, then take the dick out of your ass that got jammed in there when you jumped the gun and were wrong.
How, we got an e-thug here people. I shouldn't have even stooped to your level and degrade myself.
Aren't the SCV's for cold start up. Thats why they're there aren't they mister know-it-all? Unless you can scan the FSM's and show me the ratios, I'll keep saying that the S13's had the 8.5:1 and the S14 had 9:1. Until you get me that proof, I'll be an 'idiot'.
Hey Russ, I heard you sold your Zenki, and opted for the Kouki?
E |
![]() Join Date: Aug 2004
If a guy tells you a motor blows at a certain boost level... walk away slowly... do not spook him because he may kill you in his idiotic insanity
There isnt a preset boost level that blows a motor; bad tuning kills a motor.. wish the Silvia/240sx kids would get this through their head... i swear to god its the only group of people that actually treat this like a fruit from the tree of knowledge... :ghey:
95 Lexus SC300 5-speed -DD pimp car 92 Nissan 240sx base coupe -clean KA24DE swapped in -GTIR T28 -Big FMIC -565cc STi Injectors w/ Z32 MAF -J30 VLSD w/ subframe spacers -RPS Max clutch -3" turboback -PLMS Daughterboard on modded ECU |
#19 | |
The AIV on S13s allows for some exhaust to pulse through the intake, that would effect cold startup a little. The SCVs purpose is to function just like the throttle body butterfly and slow air down going into the head, allowing for more air pressure to build. When they open, the cams take advantage of the higher flow. That's just common sense though. How would slowing up intake air create a warm up situation? If anything, you'd want the air pressure to be at a higher velocity if you're looking for heat generation. You can keep saying whatever you want, but you're wrong and continuing to put out bad information, so the next time a thread like this comes up there'll be another argument because some new, perhaps ignorant, 240 owner hasn't researched enough and believes your comments. Those people who are intelligent enough to verify this type of information or those who are just simply knowledgeable enough to know the differences by firsthand experience don't appreciate having to continually correct mistakes that people who are too arrogant to admit they're wrong always make. It's not worth my time to go and scan FSMs, if it were then I'd have a fulltime job doing so because of hearsay from young, uneducated kids like you.
#20 | |
EDIT: guess i dont have to finish every1 else proves it
if it aint broken, fix it(95 240/96 sr20)
#21 | |
#23 | |||
![]() Join Date: Sep 2002
... Russ is beginning to act his age and birth gender, we guess Quote:
#24 |
![]() Join Date: May 2003
Hehehehe....this is funny.
ANyway, to confuse things more: SOHC: Early '89.....................9.1:1 Late-'89 to 1990..........8.6:1 DOHC: '91-98........................9.5:1 So Jeff and R240NA are both correct... - - - - - - - - - - BTW, I read about this thing on the "internet" yesterday called the "Tornado"...it said I could "supercharge any car!"...for only $69.95...WOW! I'm buying 2... - Brian
www.KA24DEvelopment.com |
#25 | |
my bad... I got confused. thanks for the correction.
#26 |
AC, and wiring, thats unheard of, he swapped out the Kouki front for a Zenki? Must not have been hard to find someone to trade.
Eric |
#27 | ||
#28 | |
Signed -Phillip Oh yeah, why would Nissan put more agressive cams in the '91's and it still have the same hp and tq outputs as the '95's with a lower duration cams?
#29 | |
