![]() Join Date: Sep 2002
deleting sunroof
i'm one tall mutha and i cant drive in my s14 se for more than and hour without back pain from hunching over. the solution...removing my sunroof and gaining another 2 inches of head room. the sparco evo2 seat on order should help too after its bolted to the floor.
I'm dropping her off at the body shop first thing in the AM. I'm so excited. I will be sure to post pics as soon as she's out of the shop. -Mike |
Step 1: Remove glass
Step 2: Sawzall roof off Step 3: Place non-sunroof sheet metal in place Step 4: Weld Step 5: Replace glass
Scott Driving Angle Motorsports |
1) remove sunroof 2) grind/cut off sunroof mounting brackets 3) weld sheet metal in place of the sunroof 4) smooth/grind welds and finish off with minimal bondo work 5) enjoy the 2" of extra headroom |
![]() Join Date: May 2003
I did a similar "sunroof delete" a few months back...I removed the OEM S14 sunroof, and replaced it with a clear sheet of plexi. I have since replaced that with a tinted piece, looks like stock from anything more than 2ft away.
Here's the writeup I did on FreshAlloy, with a few bad pics: http://forums.freshalloy.com/ubbthre...umber=67834343 - Brian
www.KA24DEvelopment.com |
![]() Join Date: Jan 2004
-disassembly
-cutting to fit -welding -grind it flush -bondo -primer -paint the fact that the roof is hard to work on due to it flexing a lot (believe me i know) adds to the pain. |
