Old 12-24-2008, 04:21 PM   #1
Jonas427
Jonas427 has a little shameless behavior in the past
Beginner timing question
I bought a timing light today to check the timing on my KA24DE. So, the timing alignment pin reads 0. I believe it should read 20. So, I tried to increase the timing but the adjustment was maxed out. Any idea what's wrong, and how to fix it?
Jonas427 is offline   Reply With Quote
Old 12-26-2008, 02:27 AM   #2
devnull
devnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymoredevnull is not welcome here anymore
Did you unplug the throttle pos sensor before starting?
devnull is offline   Reply With Quote
Old 12-26-2008, 01:26 PM   #3
Jonas427
Ok, my bad. I did forget to unplug the TPS, but now that I did unplug it the timing still looks to be off over 5 degrees.
Old 12-27-2008, 02:48 AM   #4
devnull
So it's maxed out between 10 - 15 degrees BTDC? It's possible that the distributor was not installed correctly last time. It might be off by a tooth. Have you had any services that required removal of the distributor done?
Old 12-27-2008, 07:28 AM   #5
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
Pull the distributor and reinstall. It's aligned wrong. I had the same problem a while back.
-Retired
98s14inaz is offline   Reply With Quote
Old 12-27-2008, 07:33 PM   #6
Jonas427
Well, I haven't had the car very long, so the previous owner may have removed it.
Sorry for my lack of knowledge, but how do I align the distributor correctly?
Old 12-28-2008, 05:06 AM   #7
devnull
You set #1 piston to TDC compression. Then remove the distributor assembly, line up the marks on the shaft, and reinstall it.
