Old 02-16-2011, 01:10 PM   #1
Smkns13
Smkns13's Avatar
Smkns13 is an unknown quantity at this point
Oil pan gasket
hows it goin. I need to change my oil Pan gasket on my sr20. I'd like to buy one but, I've done some research and I'm lead to believe that there isn't a oil pan gasket for sale for the sr20. So what kind of sealant should I use for this. Thanks in advance
Smkns13 is offline   Reply With Quote
Old 03-16-2011, 05:03 AM   #2
Korea
Korea is an unknown quantity at this point
you can just go to your local parts shop and look for a high temp liquid gasket, permatex has one. just make sure you apply it right and let it set. you dont wanna go blowing your engine cause your pan wasnt sealed right.
Korea is offline   Reply With Quote
Old 03-16-2011, 05:26 AM   #3
SocalCirca
SocalCirca is an unknown quantity at this point
Go to Kragen or Autozone and ask them for the part. At Autozne the part # is:
#OS30646C
It should bolt right up. Make sure you buy PERMATEX RED HIGH TEMP sealant.
SocalCirca is offline   Reply With Quote
Old 03-16-2011, 06:04 AM   #4
az_240
az_240's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
That permatex stuff isn't as good as others out there especially for an oil pan. Search around I remember someone saying there was some OEM style sealant that works much better.
Old 03-16-2011, 08:38 AM   #5
Sileighty_85
Sileighty_85's Avatar
Ive used black permatex on all the SR and KA Oil pans Ive worked on and Never had one leak.
Usually the problem is ppl using High Temp RTV on the pans.
Yes the engine gets hot but not hot enough to need High Temp, Black RTV will be fine.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 03-16-2011, 08:51 AM   #6
PoorMans180SX
PoorMans180SX's Avatar
Did you search at all? This has been covered five million times.
Black RTV. Done.
Old 03-16-2011, 10:33 AM   #7
obsolete
obsolete is an unknown quantity at this point
always the black, never the red
obsolete is offline   Reply With Quote
Old 03-16-2011, 12:47 PM   #8
jacobs13
jacobs13's Avatar
jacobs13 is an unknown quantity at this point
Oem sealant I heard doesnt dry, get the black rtv
jacobs13 is offline   Reply With Quote
Old 03-17-2011, 07:26 AM   #9
Smkns13
Smkns13's Avatar
Thanks everyone. Im gonna put in some work this weekend doin that, a radiator and a diff. Thanks for the info
One
Old 03-18-2011, 04:42 AM   #10
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
Have fun. The oil pan is a bitch haha.
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 03-18-2011, 08:11 AM   #11
Sileighty_85
Its not that bad, I just did one yesterday on the ground, way better if you got a Lift though.
後輪駆動車1番
1986 SR86 - 200ish
Old 03-18-2011, 11:29 AM   #12
Pro ViZIon
Pro ViZIon's Avatar
Yeah that's what I had to do. And jack up the engine from the tranny bell housing. My nismo power brace got in the way of removing the pan.
To op you should also unbolt the sway bar where it mounts to the frame. 2 14mm bolts each side.
Old 03-18-2011, 05:26 PM   #13
95_S14
95_S14's Avatar
Trader Rating: (108)
95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future
Feedback Score: 108 reviews
If you clean the block and the pan it's the best stuff out there I don't use anythin but oem it's not cheap but you get what you pay for it's 15 for thu tube and it will cover your pan water pump and thermostat housing
95_S14 is offline   Reply With Quote
