sr20det rev problem!!
so i just swapped an SR into a s13. and it drives perfectly normal UNDER 3500 RPM.. when i hit 3500 rpm it bogs and the rpm drops even tho im still on the throttle... and its only boosting 3psi.. ideas anyone??
Wrong MAF, Coolant Temp Sensor, or harness problem are the most likely issues. You would find this already answered a few ways in the Engine Tech Forum if you used the search in there.
Good luck.
89 240SX w S14 SR20; 95 JDM 180SX S13 SR20; 09 Acura TL SH; 18 Jaguar XE S |
