Old 10-14-2008, 11:40 AM   #1
Impact Black
Impact Black is an unknown quantity at this point
hood not flush
I installed a S13 frontend on my car. The OEM parts sat fine however I put the S13 frontend on and the hood doesn't seemt o go all the way down.
I was wondering if you have to lower the actual hood latch in order for it to sit snug with the lights. The hood lines up with the fenders, just seems like the latch is high which isn't allowing the hood to sit flush with the headlights, thus leaving about a 1'' gap
Just asking, appriciate any help.
Impact Black is offline   Reply With Quote
Old 10-14-2008, 11:48 AM   #2
Charlie
Trader Rating: (35)
Charlie is on the path to ruinCharlie is on the path to ruin
Feedback Score: 35 reviews
When I had a silvia front on my car the hood didn't close right so I adjusted the latch.
Charlie is offline   Reply With Quote
Old 10-14-2008, 04:35 PM   #3
Impact Black
so its the actual hood latch that needs to be adjusted?
It seems to me that I just need to move it down an inch and it should sit perfectly.
I will take pictures before and after and post them up
Old 10-14-2008, 04:47 PM   #4
WaNa-DrIft
WaNa-DrIft's Avatar
WaNa-DrIft is an unknown quantity at this point
oww...really good info cuz im getting a s13 front too...hmm
Where ohh where to find my love...Silvia, please come to me once more.
WaNa-DrIft is offline   Reply With Quote
Old 10-14-2008, 04:52 PM   #5
GSXRJJordan
GSXRJJordan's Avatar
Yes the latch has a little adjustment in all directions (up/down/left/right), but there's nowhere near an inch of adjustment. It might be sitting slightly to the side, so the hood isn't going all the way down into the latch.
Old 10-14-2008, 05:09 PM   #6
its_teddd
its_teddd's Avatar
its_teddd has a spectacular aura aboutits_teddd has a spectacular aura aboutits_teddd has a spectacular aura aboutits_teddd has a spectacular aura aboutits_teddd has a spectacular aura aboutits_teddd has a spectacular aura about
it might be the black rubber things on the sides. thats what it was for me but then i had a cf hood so what do i know
its_teddd is offline   Reply With Quote
Old 10-14-2008, 05:29 PM   #7
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
When I installed my cf hood on my s14 I had the same issue. Ended up taking off the latch, taking a drill to it, and slotting the holes for the hood latch so that I could have more adjustment. Now it sits nice
http://blog.dapcwiz.com
DaPCWiz is offline   Reply With Quote
Old 10-16-2008, 09:57 AM   #8
Impact Black
OK, so I've been busy and haven't had the time to adjust the latch yet.
The hood is a charge speed hood, with the vent in the middle (don't know if anyone has had issues with this hood)
Its latched just not sitting flush as of now...and its PISSING ME OFF AS TO WHY it isn't,lol.
I've already removed the black rubber stoppers and still nothing.
GSRJJordan,
I've pretty much got the hood aligned with the fenders, so I'm not sure how its sitting to the side of either way.
Guess if I can't figure it out its off to a body shop. I really REALLY don't want to drill the hood and do the hood pins option.
Old 10-16-2008, 11:20 AM   #9
DaPCWiz
DaPCWiz's Avatar
GSRJJordan,
if its a cf/fiber glass hood... it can tear from the factory latch at high speeds. Hood pins are highly recommended. That said, I drove with my car w/o pins for like 6+ months no real issues. THe hood used to noticably shake tho. I got some aerocatch pins to keep my mind at ease.
Old 10-16-2008, 03:25 PM   #10
Sileighty_85
Sileighty_85's Avatar
I dont know.... I have a Fiber Glass Aerokits.net hood only running the stock latch and i'll hit 130mph and it still holds.
Then again I dont give 2 shits about my hood
Id imagine a charged speed hood would be made better. so you should be ok with out hood pins, unless the hood latch itself fails.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 10-16-2008, 07:26 PM   #11
DaPCWiz
DaPCWiz's Avatar
I've never had anything bad happen with my hood, the latch held perfectly find for those 6 months with no signs of wear... but most manufaturers of hoods recommend hood pins. I've also heard too many horror stories... better safe than sorry I guess... I guess I"m the nervous type, lol.
Old 10-16-2008, 07:31 PM   #12
SqueekyClean
SqueekyClean is an unknown quantity at this point
You know, you just have to play with all the variables.
Hood hinge bolts, and the latch.
Those are the only 3 variables that effect the Hood.
AS WELL AS THOSE RUBBER GROMMETS THAT THE HOOD SITS ON, UPON CLOSING!!!!! CHECK AND LOWER OR RAISE THEM. PEOPLE TEND TO FORGET ABOUT EM.
With carbon fiber and fiberglass hoods, it takes time and months in the heat for the material to flex in place and they never fit correctly to begin with.
SqueekyClean is offline   Reply With Quote
Old 11-07-2008, 11:28 AM   #13
Impact Black
Sorry to bring a thread back from the dead.
So get this, I took it to my friends body shop and we were talking. I told him about how the hood wouldn't sit right.
He yells out something in spanish and this little guy comes from around back. He points at the car tells him to adjust the hood.
The little guy looks at it for 5min...comes back with tools and 2min later the hood is sitting flush,lol
Goes to show, body guys with experiance know their stuff
