All you road racers
What size wheels are you guys running, with what tire size. I am in the final steps of wheel selection for my trackcar, and i am curious to see some other set ups out there. These wheels will not be used on the streets, nor will i be drifting in them, or autoxing, so a short sidewall will not be necessary.
WOW addicted
![]() Join Date: Dec 2001
Try to get 16's in an 8 or 8.5" width all around. The car is most balanced with a non-staggered setup. The width will allow you to run 225-245 width tires. Either work well.
I prefer 16's as they make the car feel less sluggish, and give you some sidewall choice flexibility.
for track days i would go with 16x8/8.5 as well and a 235 series (225 i think is ideal) tire max if your putting down less than 300 horse...at least if your running full blown slicks.
track tires need a lot of heat to work properly...and something like a 255 series tire with only ~200 horse will take awhile to heat up.
"Good, Bad, Im the guy with gun" |
If you go with something less than slicks or even R compounds (something like azenis sports), then it wont take too long to heat up. So i would go about as wide as possible (to an extent), id say no wider than a 255 or so would be PLENTY of tire. 225 leaves a little grip to be desired, the new azenis (if you go with a 17" rim) comes in a 245/45/17, and a 255/40/17.
If you go with something less than slicks or even R compounds (something like azenis sports), then it wont take too long to heat up. So i would go about as wide as possible (to an extent), id say no wider than a 255 or so would be PLENTY of tire. 225 leaves a little grip to be desired, the new azenis (if you go with a 17" rim) comes in a 245/45/17, and a 255/40/17, on the 8" rim, go with a 245, on the 8.5" go with the 255.
I was thinking of running of 17x8.5 or 17x9 all around, but i think the 16x8.5 is the best bet. Oh and i am putting down 300 ponies already, and hope to have ruffly 325 realible horsepower , and simlar torque for trackdays, (s13 redtop) and i am thinking of running kumho mxs. Any other open lappers care to share with what seems to work the best?
Oh and these wheels are for an S14 if that helps. tia |
yea you can fit 17x9 all around on an s14. On an s13, i dunno, with perfect offsets maybe, but without that, i dont thikn you could fit that up front
I have Kumho MXs on my car. On the track they stick ok - on par with Azenis Sports. Probably the most grip you will get on street tires besides the G-force KDs. If you have the money I'd go with R-compounds but that's not practical if you daily drive the car or don't have another set of wheels.
I have a S13 with a SR blacktop motor and it works well with a staggered 205/225 F/R set up on 16"x7/8 but then I'd probably want to run something wider if I had wider wheels. I have some traction problems accelerating out corners as the rear end wants to come out under throttle.
SOLD: 91 240SX Coupe SR20DET, 05 Evolution 8 NEW: 08 Evoluton 10 |
maybe soften the rear ZK....
Bdubs- what sort of tire budget do you have? Buy wheels based on the tire $ and size you can afford to run. imo 17's are larger than necessary BUT that depends on your brakes.
Finally down to 1 car again. Thank god. |
#11 | |
budget is not the concern. Although the car will be street driven. And the mxs are the most cost effective tire in that regrads. Im not sure yet which brakes im going with, but i would think they would fit in most dished 16s. As for brakes what is everyone running here as well. I know z32 s the most cost effecitive way but how well do they hold up, fade ect, braking strength.
ive got the z32s and only really do autoX and haven't had a problem at all with em. They stop like a postwar economy, and theres NO fade. Im gonna run my first roadcourse on em on the 27th, ill post them how the car was.
#14 | |
Z32 brakes work great, just make sure to have some good brake pads.
SOLD: 91 240SX Coupe SR20DET, 05 Evolution 8 NEW: 08 Evoluton 10 Last edited by ZK; 02-18-2005 at 03:55 PM.. |
^i use PBR ceramic/metallic pads and they work excellent.
souds good, z32 sounds like the most fesable option, ill just get some carbon kelvar pads. So 16X 8.5 should be a good wheel with +25 or +30 all around, or a 17x8.5 around with similar offset?
