Old 06-24-2014, 03:45 PM   #1
JohnWallace3
JohnWallace3 is an unknown quantity at this point
SR 240 and s13 blacktop sr20 parts for sale
-s13 5 speed transmission, no pops or grinds, its just dirty ill clean it before you get it-$300
-SR T25 turbo with manifold and elbow-$250
-SR20DET Blacktop E5 ECU with what I believe is a z32 maf chip-$150
-Z32 MAF-$50
*I can package ecu and z32 maf for $190
-Complete sr20det blacktop stock engine harness-$125
-Stock sr20det fuel rail and stock injectors-$70
-OEM SR20DET coils x4-$20ea-$75 for all 4
-SR20DET CAS known good just has broken cover-$50
-SR knock sensor and harness-$30
-Real SR20DET A/C compressor (not KA with braket kit) I don’t know if it works so its cheap-$50
-SR20DET power steering pump-$30
-OEM SR20DET clutch Fan-$35
-SR20DET Clutch/flywheel/pressureplate, came off a motor I ordered that I rebuilt which appeared to only have about 20,000 miles the clutch looks almost new-$125
-OEM 240sx Front calipers I have left side and right side-$40ea
-OEM 240sx Rear calipers I have 2 left side and 2 right side-$35ea
-Plate welded differential really smooth fluid comes out clean no sparkles every time changed regularly-$50
-I have tons of other s13 hatch parts and a lot of other external sr20det parts. hit me up for questions and I may be willing to trade if what you got is useful to me.
Things I may be interested in
-z32 ebrake hub
-I need a decent pair of 225/45/17
-Wheels no knock off crap 17' maybe 18' 9.5 low offset if you got mb battles or rpf1s and you want something I may be willing to put cash on top.
JohnWallace3 is offline   Reply With Quote
Old 06-25-2014, 09:06 AM   #2
juanm203
juanm203 is an unknown quantity at this point
Location ? Txt me bro 323 3997234
juanm203 is offline   Reply With Quote
Old 11-21-2017, 09:18 PM   #3
Suzziethe240
Suzziethe240 is an unknown quantity at this point
Do u still have sr20det blacktop harness
Suzziethe240 is offline   Reply With Quote
Old 11-21-2017, 10:15 PM   #4
Simply fresh
Simply fresh is an unknown quantity at this point
Interested in the ecu
Simply fresh is offline   Reply With Quote
240sx, parts, s13, sr20det
