Old 03-15-2008, 03:10 PM   #1
ZilviaBot
Zilvia.net Bot
Post Nissan GT-R meets the dyno, a 997 Porsche Turbo and an E92 BMW M3
Filed under: Tuners, Sports/GTs, Nissan
It was only a matter of time before the first consumer-owned Nissan GT-R in the U.S. made its way onto a set of dyno rollers. Edmunds Inside Line made the call to Harman Motive, Road Race Engineering (RRE) and Daryl Alison of JSpec Connect to organize a day of data collecting recently for the import from Japan. Harman and RRE happen to each house all-wheel-drive-capable dynos, with a Mustang and Dynapack, respectively. The two units were chosen because they each utilize different means of measuring vehicle power output, making for a range of results that can be more readily used for comparison purposes. And compare they do as a 997 Porsche 911 Turbo and 2008 BMW M3 happened to show up at the testing facilities that very same day, fancy that. Follow the jump to get a handle on the results.
Gallery: Nissan GT-R Dyno Test
Continue reading Nissan GT-R meets the dyno, a 997 Porsche Turbo and an E92 BMW M3
Â*
ReadÂ*|Â*Permalink | Email this | Comments
More...
HTML code is On
