Old 08-16-2008, 11:13 AM   #1
Devens240
Devens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really nice
clearing 10" wide wheels on S13
Hey i was wondering if i could tuck 10" wide wheels (rear) on an s13 with less than 1 degree of camber and only a roll and pull. also would a 255 or a 275 be square? i dont want to stretch...
Devens240 is offline   Reply With Quote
Old 08-16-2008, 11:17 AM   #2
kevtrinh
kevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond repute
wat.
asfsfasfsfsfsfs
Team Pterodactyl
kevtrinh is offline   Reply With Quote
Old 08-16-2008, 11:19 AM   #3
arkive43
arkive43's Avatar
arkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud of
easy...run 245's
arkive43 is offline   Reply With Quote
Old 08-16-2008, 11:20 AM   #4
Devens240
i dont want to stretch, i would like to run 275/40/17's
Old 08-16-2008, 11:22 AM   #5
arkive43
arkive43's Avatar
275's are gona rub if u wana tuck ur gona have to have a slight stretch
Old 08-16-2008, 11:22 AM   #6
JVD
JVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfection
Dude... it's all about offset. Telling us 10" rim and 275 tire means nothing.
JVD is offline   Reply With Quote
Old 08-16-2008, 11:25 AM   #7
i8yourfwd
i8yourfwd's Avatar
i8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfection
Send a message via AIM to i8yourfwd
I could be wrong, but I don't think it's possible to fit a 10" wheel with only a minor pull if you only one a degree or so of camber and wanting to run a 275. Unless of course you're not that low, but then you're not tucking.. sooo yeah.
Check that max rubber thread that was floating around.
http://jaythroughglass.blogspot.com
S13SilviaGirl: Mel are you that big?
i8yourfwd is offline   Reply With Quote
Old 08-16-2008, 11:27 AM   #8
JVD
I think you should be able to. Just gotta pick the proper offset.
EDIT: And who the fuck runs 1 degree of camber?... oh, unless it's a drag car maybe???
Old 08-16-2008, 11:53 AM   #9
Z33dori
Z33dori's Avatar
im pretty sure there is a thread on this
it can be found by using the search button.
Old 08-16-2008, 11:57 AM   #10
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
offset is the only thing that matters here
JRas is offline   Reply With Quote
Old 08-16-2008, 11:59 AM   #11
LB.Motoring
LB.Motoring's Avatar
I dont know how youd tuck a 10" wheel,
its pretty small...
dumbass....
Robby Leuer
Old 08-16-2008, 12:14 PM   #12
Z33dori
Z33dori's Avatar
lol repped..
that is what i thought when i read the title ... then i read.... lol
Old 08-16-2008, 12:35 PM   #13
SexPanda
SexPanda's Avatar
Honestly, a 9 in the rear would work just fine. 10 is cutting it real close. Thats a big ass wheel.
once you reach a certian width, you stop gaining that stability factor, and start loosing important stuff like tire prices, drag, et cetera.
Old 08-16-2008, 12:55 PM   #14
Martin_s14
Martin_s14's Avatar
Martin_s14 is a name known to allMartin_s14 is a name known to allMartin_s14 is a name known to allMartin_s14 is a name known to allMartin_s14 is a name known to allMartin_s14 is a name known to allMartin_s14 is a name known to allMartin_s14 is a name known to allMartin_s14 is a name known to allMartin_s14 is a name known to allMartin_s14 is a name known to all
DUUUUUDE!!!! -1 degree of camber??? That is just nuts!! I can't wait to see what this will look like!!! 10" OMGEEEZ!!!
Martin_s14 is offline   Reply With Quote
Old 08-16-2008, 01:08 PM   #15
Devens240
yes im puttin an LS1 in so i need plenty of tire on the ground. and 10" wide. i know it all depends on the offset, but is there any offset i can run and tuck 10" with little to no camber i have a fender roller but i dont want to pull it too much
Old 08-16-2008, 01:22 PM   #16
ThatGuy
Admin Asshole
ThatGuy's Avatar
18x10 +20mm with a 245 tire.
Not alot of camber and requires the slight stretched tire and this much pull.
When I had the wheel at +35mm, I ran into rubbing problems on the suspension arms. That was the wheel rubbing, a larger tire wouldv'e needed even less offset, in my opinion, to properly clear.
Old 08-16-2008, 02:19 PM   #17
Devens240
ok, i dont want stretched tires though, its going to be a autox car and maybe drag once and a while
Old 08-16-2008, 02:28 PM   #18
RPS13-604
RPS13-604's Avatar
RPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really nice
im running on work meister s1 3pc +18 O-disk 18x10 on 255/35/18 with a fender pull and roll still havent had the time to camber it in yet but right now the rears stick out about 1inch
RPS13-604 is offline   Reply With Quote
Old 08-16-2008, 02:30 PM   #19
ayuaddict
ayuaddict's Avatar
so you dont like stretch.
but you wanna tuck wheel?
so like...
you want as much tire as you can possibly fit to make up for your fucked to shit suspension geometry?
are you like, bipolar?
Old 08-16-2008, 02:30 PM   #20
RurouniMidnight
RurouniMidnight's Avatar
Just get a 9 inch wheel with decent offset and run a 255 265 and roll fenders and pull it how you want, it can't be absolutly perfect you have to give from a certain area to gain elsewheres, wider wheel = more of a streched tire and more rolling and pulling, it really comes down to just doing it and dialing it to make it comprimise and fit and look how you want it.
Old 08-16-2008, 02:45 PM   #21
Devens240
so like...
fucked suspension geometry? since when is 0 degress camber fucked up suspension geometry? and no i dont like streched tires why by wide wheels then put tiny tires on them if im not going to drift?
Old 08-16-2008, 03:09 PM   #22
ayuaddict
ayuaddict's Avatar
if you are tucking wheel, your shit is going to be all bad. all that roll couple and roll center and all that jazz.
you know, from being low?
Old 08-16-2008, 03:12 PM   #23
ThatGuy
Admin Asshole
ThatGuy's Avatar
Not to mention if you want to tuck wheel and run Auto-x that means your shit would have to be SUNK. If not you're going to chew the hell out of the sidewalls of those non-stretched tires. You do realize the rear wheels and tires move when you take hard corners, right?
And if it's used for Drag racing, having the rear end dropped that far will not yield good launches.
I think you need to rethink what it is you actually want.
Old 08-16-2008, 03:12 PM   #24
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
^ He's refering to the fact that you want to tuck. Slamming a 240sx to tuck is fucking the geometry but of course it depends on teh dia. of the wheel as well.
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 08-16-2008, 03:14 PM   #25
Matej
You're going to put an LS1 in it, but you don't want to modify the fenders?
Old 08-16-2008, 03:14 PM   #26
ericcastro
ericcastro's Avatar
just so you know. I run stretched tires on auto cross and Grip courses. With a welded diff and still am able to keep it in (keep it from sliding).
if you dont want to stretch, it sounds like maybe you should run a 9, not a 10. If you dont mind stretching, then run a 10.
and Im not talking about Xtreme stretching. Im talking like a tiny bit. Like my 195 on 8's.
How wide can you go on a 10 and how wide can you go on a 9 BTW?? and still fit??
Is it the rules of the division you wanna run that say you cant roll the fenders or just buy over fenders??
What size you running up front and what Diff??
Actually, Ididnt even think of this. For best auto cross performance you dont want the car so low that 17's can "tuck".
You want to keep those arm just above level, or the suspension cant work as it was designed.
If your getting serious about AutoX. Pick up a couple of the books on it. The AutoX community knows an amazing about of info!!!
Old 08-16-2008, 03:23 PM   #27
RPS13-604
RPS13-604's Avatar
just go widebody and forget the tire sizing haha
Old 08-16-2008, 04:35 PM   #28
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
I thought he was talking about a 10" wheel diameter and not width for a second.
Old 08-16-2008, 04:39 PM   #29
Pank
Pank's Avatar
Pank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfection
C5 vettes (that came with ls1s, and are heavier), came with 18x9.5's on the rear, so i think you'll be fine with 9's, esp if you're not stretching
high performance driveway photography
zenki s14---v8 fc rx7
my crappy flickr page (drift cars whoo)
Pank is offline   Reply With Quote
Old 08-16-2008, 04:43 PM   #30
WISH ONE
WISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfection
Send a message via AIM to WISH ONE
..........+40
PARTING/SELLING MY COUPE. PM ME.
WISH ONE is offline   Reply With Quote
