Old 04-24-2012, 11:32 PM   #1
saliaga08
saliaga08 is an unknown quantity at this point
s14 help! s14 sr20det cutting out
Alright I just did a s14sr to my s14 starts up perfect idles just fine boost is at 10lbs right now. Now for the issue, running the car to 4500rpm and it bogs out if I step on the accelerator to the floor it goes to 5500rpm then bogs.
What im running:fmic, isis rad and efans, hks ssqv4 bov, hks actuator, custom intake, and a s14sr maf.
Things Ive done so far. Replaced fuel pump with a walbro 255 and sparkplugs with ngk. Check all my wiring and everything is fine also did countless searches on this but none of them is really helpful so now I'm lost
saliaga08 is offline   Reply With Quote
Old 04-24-2012, 11:35 PM   #2
reallygood101
reallygood101 will become famous soon enoughreallygood101 will become famous soon enoughreallygood101 will become famous soon enoughreallygood101 will become famous soon enough
boost leak, prolly due to your bov opening under boost
reallygood101 is offline   Reply With Quote
Old 04-25-2012, 07:33 AM   #3
Silvia716
Silvia716 is an unknown quantity at this point
Your maf could be bad too
Silvia716 is offline   Reply With Quote
Old 04-25-2012, 12:32 PM   #4
reallygood101
is the sr20 kouki or zenki, i had somewat of the same problem come to find out i had the wrong ecu, wire harness and maf, switched that stuff out and now it runs like a champ... is the car running rich wit black smoke coming out of the exhaust
Old 04-26-2012, 08:56 AM   #5
saliaga08
Checked for boost leak, Im ok in that area. Thanks for the input
This is the second maf and its doing the same thing as the 1st but I tested it and its operating fine. Thanks for your input.
I hope its not the wrong ecu. I bought my swap from JDMdepot. How do I find out if its the wrong ecu for the engine?
Old 04-26-2012, 09:12 PM   #6
saliaga08
I did a boost leak test and had no leak but maybe I'm wrong. How would I go about fixing that? It is a brand new HKS bov not a knock off.
Old 04-27-2012, 02:52 AM   #7
Walperstyle
Walperstyle's Avatar
boost leak is more then just a BOV issue. It could be a hole in your intake, vac line disconnected, or a coupler off sucking in un-recognized air.
anyways, what injectors do you have and are they high or low impedance?
KA-T ORG-Function over Flush
Old 04-27-2012, 02:54 PM   #8
saliaga08
stock injectors
Old 05-07-2012, 10:06 PM   #9
Nismo11
Nismo11 is an unknown quantity at this point
Did u ever find the problem?
Nismo11 is offline   Reply With Quote
Old 05-08-2012, 08:29 PM   #10
swift14
swift14 is an unknown quantity at this point
are you running any air fuel controller leading to your ecu?
swift14 is offline   Reply With Quote
Old 05-08-2012, 09:18 PM   #11
saliaga08
No and no Im going to dig into it next week haven't had the time
Old 06-11-2012, 10:24 AM   #12
saliaga08
Alright back from the grave.
I have replaced all vacuum lines, boost lines, fuel lines ect. new fpr new fuel pump new maf. All grounds are grounded, all wiring is secure, everything is fresh. Now Im still bogging out at 5500 rpms and if I ride it thru it goes to 6500-7000 and bogs there.
Old 06-11-2012, 04:40 PM   #13
projectblak
projectblak is an unknown quantity at this point
U may be running rich, I tuned my car on a safc and on the first few pulls it was running rich and would bog at 5000 rpm fixed the air fuel mix and now pulls hard to redline. Boost was at 10 pounds.
projectblak is offline   Reply With Quote
Old 06-11-2012, 05:57 PM   #14
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Check your mechanical timing and make sure its good. Then double check your baseline timing. For spark plugs what are you running and what is it gapped to?
CLICK HERE!!!
Old 06-11-2012, 06:39 PM   #15
saliaga08
Yeah tuning is my next step.
Old 06-11-2012, 06:43 PM   #16
saliaga08
Well I have brand new ngk 7 at the gap the came running 13lbs of boost right now
Old 06-11-2012, 06:48 PM   #17
fliprayzin240sx
Its probably gapped too wide...get a gapper and gap them down to .030. Most off the shelf plugs are gapped anywhere between .044 to .056.
CLICK HERE!!!
Old 06-11-2012, 07:14 PM   #18
AsleepAltima
AsleepAltima's Avatar
AsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura about
stupid question maybe, but what octane fuel are you using?
AsleepAltima is offline   Reply With Quote
Old 06-11-2012, 08:17 PM   #19
projectblak
Yes yes. I forgot to mention this too he is correct I had 7 Ngk plugs and it was misfiring as well and bogging. switched to a gap plug and it went away instantly..
