Old 04-15-2020, 06:14 PM   #1
brn-n-jpn
brn-n-jpn's Avatar
brn-n-jpn is an unknown quantity at this point
Send a message via AIM to brn-n-jpn
No spark after warming up
Anyone have any clue one what could be wrong...
So my cas works intermittently.
I plugged in my aem boost and oil pressure gauges one pin,like an idiot, over which cause a backed feed to the voltage regulator and cas to stop working. I then plugged gauges in correctly installed new alternator and another cas. Cranked the car with fuel pump unplugged to make sure there was spark. I then plugged fuel pump in and started the car. Everything was working fine until I noticed the car getting hot so I shut it off. Figured out that I unplugged radiator fan, once that was fixed I went to crank the car and NO SPARK.
I took one of my spare cas and plugged in with the key in the on position. While I'm spinning the cas gear by hand, the car has spark. But if I plug into the cas in the head no spark.
I pulled the cas from the head thinking it was bad but when I plug it in, have the key in the on position,and spin cas by hand I have spark.
Went to the garage today and cranked the car with original cas still in it and the car started right up.
I let the car warm up and fans cycled a few times then shut it off. Went to start it back up and no spark but if I plug spare cas in and spin the gear by hand it has spark.
Any ideas will be much appreciated before I burn this 9 year project to the ground.
brn-n-jpn is offline   Reply With Quote
Old 04-15-2020, 10:39 PM   #2
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
See if you have a 5v when it's not sparking.
mechanicalmoron is offline   Reply With Quote
Old 04-17-2020, 02:58 AM   #3
anthony_240
anthony_240's Avatar
anthony_240 is an unknown quantity at this point
Check the pins/ wiring in the cas connector. With heat from the motor they could expand causing an open. If you have a dmm check resistance in wiring while cold then when hot.
Or you can cold start it and wiggle wiring around
anthony_240 is offline   Reply With Quote
cas timing sr20det cams, no spark, sr20, start up problems
