07-31-2011, 08:06 PM | #31 | |
07-31-2011, 08:15 PM | #32 |
You could deff run 400hp all day on 21 psi with stock internals. I feel like if u keep your setup basic the engines seem to run alot longer. Just remember your gonna be pushing alot of parts to there max so dont expect for it to last forever if u hit 500hp on a sr.
07-31-2011, 08:22 PM | #34 |
depends where you put yout MAF i've heard thousands of stories ppl puting it 8-12inchs front the T.B, other putting it between filter and turbo (has it was on the oem setup) because i'll be running topmount obviously
08-01-2011, 10:48 PM | #35 |
Trader Rating: (58)
Feedback Score: 58 reviews
If you want a MAF the only true way to run is is draw through (before turbo) if you are even considering blow through, you may as well run a MAP
Want Air Conditioning in your SR20 Swapped car? Check out www.sr20acbrackets.com for more information! Quest Alternator Conversions for SR20! Check my Group Buy! Tired of lousy internal gates? Go external wastegate with one of my manifolds, Check out my group buy |
08-05-2011, 05:39 AM | #36 |
@Cody: Quebec is in Canada... not Europe
* If you want to keep side feed you can run 4 bar fuelpressure on 740's. Should be enough for 500bhp (~450 whp). * If you want to keep the VCT on the S14 DET you can look for TODA cams if HKS are in backorder. Got them in my S14 DET engine and run great. What 3071 are you going to run? The T2 bottom mount seems to have a bad reputation of being restrictive and having problems for controling boost. No personal experience btw. Good luck with the built.
JDMstyle-Driftstyle-Dish-Stickerbomb-Stretch-Bye Bye Kitty... |
08-05-2011, 07:06 AM | #37 |
740s at 4 bar wont work, yeah it may get you the 500hp you want but the injectors are wayy over their duty cycle. you dont want injectors to run more than 80% of their duty cycle, if you were to use 740s they would be at almost 90%..the safe way would be to switch to top feed and use the 1000s, that way its still in their safe duty cycle range and you have plenty of room for more power if you were to ever want it
top feed costs a lot more but big power = big $$$
'92 240sx w/'93 SR Blacktop /// '94 RX7 FD3S /// '11 370z RIP |
08-05-2011, 08:21 AM | #38 | |||
Trader Rating: (58)
LOL! I saw the word French and made a mistake there! LOL. And to think I've been to Montreal!
In regard to duty cycle, that's very oldschool in relation to injector. If he was running an old Rochester/MSD style injector then I'd agree to keep duty cycle lower (specifically the 50lb MSD) but the 72 lbs and the newer RC injectors would be ok at higher duty cycle. 740's would be enough to support 500 whp, but would be close to full on. If they were run at 4 bar they would be more than enough. However with all of this talk, if 500whp is the goal, looking into -6 line may not be a bad idea here, and even looking at an Aeromotive Stealth Pump or even a Bosch 044.
08-05-2011, 10:32 AM | #39 |
i was always taught to never go above 80% duty cycle but hey i learn something new everyday haha
but if he were to go with the RC 740s it would be about the same cost (if not more depending on where you get them) as the ID1000s and like codyace was saying to get the -6 lines you would have to get a new rail anyway so might as well get a nice top feed.. =]
