Old 07-20-2015, 03:10 PM   #1
Coreypell
Coreypell is an unknown quantity at this point
s13 Sr20det Idle issue and no throttle response
Recently got my sr20det swapped and KINDA running. basically when i start it up it has a weird high pulsing idle and no throttle response. Its kind of a vague explanation but i have a link to a video i took of the engine. Any help in figuring out whats wrong would be awesome! Thanks!
https://www.youtube.com/watch?v=S30O2jHR71U
Coreypell is offline   Reply With Quote
Old 08-03-2015, 10:40 AM   #2
adey
adey's Avatar
adey is an unknown quantity at this point
Check your Throttle Position Sensor - is the wiring good? the sensor? all plugged in?
adey is offline   Reply With Quote
Old 08-03-2015, 11:07 AM   #3
cotbu
cotbu's Avatar
Do a power balance test, spark and fuel. pull codes
Old 08-11-2015, 02:33 PM   #4
daryl337
daryl337's Avatar
daryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura about
Send a message via MSN to daryl337
Check MAFS.
The pulsing idle like that is almost universally associated with MAFS issues
This is my clever and witty signature.
daryl337 is offline   Reply With Quote
Old 09-22-2015, 03:23 PM   #5
Coreypell
Finally was able to start working on the car again. I went ahead and pulled the codes and it comes up with 2.
Code 12 - Air Flow Meter
Code 34 - Knock Sensor
I checked all the voltages going to the MAF.
The black/white stripe wire reads 11.6v almost battery voltage and the brownish with wire fluctuates between .03v and .06v while its running the way it is.
Old 10-29-2015, 11:26 AM   #6
Coreypell
Figured it out. It was the maf. I ordered a new maf fired right up like normal
