Old 01-30-2019, 10:16 AM   #1
soryu
soryu's Avatar
soryu is an unknown quantity at this point
s13 Isr coilover rear spacer??
I dropped some isr coils on the 240 , but there is some spacers(washers) that came with the kit. Does any one know what they do? Or when are they needed?
Currently not installed.
soryu is offline   Reply With Quote
Old 01-30-2019, 10:24 AM   #2
hatchdrift
hatchdrift is an unknown quantity at this point
Between lower mount and the bolt holding to knuckle
hatchdrift is offline   Reply With Quote
Old 01-31-2019, 10:10 AM   #3
soryu
soryu's Avatar
Thanks, what are they used for? Aftermarket knuckles?
Old 01-31-2019, 06:56 PM   #4
Memberofthe600hpkaclub
Memberofthe600hpkaclub's Avatar
Memberofthe600hpkaclub is an unknown quantity at this point
Helps the coil clear the rear knuckle better
Memberofthe600hpkaclub is offline   Reply With Quote
Old 02-01-2019, 03:35 PM   #5
soryu
soryu's Avatar
The coils went in without a problem, should I install them? Any risk running without them?
