For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
06-27-2011, 04:53 PM | #1 |
RB20/25/26 parts......cheap
HKS Pistons/Rods...... SOLD
Turbo kit.......SOLD N1 Water pump....SOLD Clutch Fan...........SOLD Injectors and Rail.........SOLD Wheels....SOLD Please contact me if you have any questions about the items listed. All items will be shipped through FedEx second day air, as I get it at the same price as ground through work. Willing to negotiate on the prices if multiple items are purchased. Thanks a lot. and talk to you soon Most of these items can be adapted to work with other RB engines. There are many writes up on converting RB20/RB25's to ITB setups. With the fuel rail and resistors, the injectors can be used on the RB25. The cams can be used in an RB20. You get the idea.... RB26DETT OEM intake plenum (glass beaded, and ready for finishing or installed as is) $150 RB20 ITB conversion write up AZ240SX.org Forums > RB20 w/ RB26 ITB's RB26DETT OEM ITB's $200 These are the stock wheels from my 2003 Nissan 350Z Track Edition produced by Rays Engineering. They are a forged aluminum, very lightweight, and a common track use wheel. They are in great shape, aside from the one dent that is pointed out in the pictures, which is not that bad. The tires are good, aside from one which needs to be replaced. Available for pickup only in Edison NJ. $600 OBO SOLD SOLD SOLD Front Size: 18x8.0 Offset: +30mm Weight: 18.19lbs Tire: 225/45/18 Rear Size: 18x8.5 Offset: +33mm Weight: 18.62lbs Tire: 245/45/18 RB26DETT HKS 88mm pistons and OEM rods (perfect for someone with damaged cylinder walls or that wants more displacement. You could imagine how much these cost new $$$)$350 SOLD.....SOLD.....SOLD RB26 HKS Twin top mount turbo kit (Old school cast manifolds, twin HKS wastegates, disassembled twin TD05 16g turbos (rebuild kits included, 1 turbo elbow. Everything has been bead blasted, and looks great) $500 Old Pictures SOLD.....SOLD.......SOLD RB26DETT OEM camshafts $100 RB26DETT OEM springs and retainers (2 complete sets) $100 each RB26DETT OEM Headgasket *New* $50 RB26DETT N1 water pump $80 SOLD RB26DETT OEM oil pump $80 RB26DETT OEM coils (Probably compatible with other RB engines with external igniters) $200 RB26DETT OEM injectors 440cc$100 (can be used on other RB engines with the RB26 rail) SOLD....SOLD....SOLD RB26DETT OEM fuel rail $50 SOLD......SOLD....SOLD RB26DETT OEM AAC $50 RB26DETT OEM IAC $50 RB26DETT OEM steering pump $75 RB26DETT OEM A/C idler $20 RB26DETT OEM clutch fan $30 SOLD....SOLD....SOLD Last edited by doyle4281; 07-26-2011 at 10:05 PM.. |
07-01-2011, 04:28 PM | #14 |
They appear to be there to me.
also, the turbo kit is SOLD to me... ****Dude it totally legit, I got the kit in today, better than expected!**** Last edited by Krazykouki; 07-06-2011 at 11:42 AM.. |
07-26-2011, 10:16 PM | #23 | ||
460
