Old 12-04-2016, 06:16 PM   #1
duncan351
duncan351's Avatar
duncan351 is an unknown quantity at this point
Send a message via AIM to duncan351
KA 843whp @40psi KA-T
Not a bad day at the dyno today.
I stopped at 843 when I blew the weld on my intake manifold. You won't see the 843 graph because I forgot to clamp the dyno pick up signal after regapping the spark plugs but the dyno still recorded the pull. Still more left in the motor but I'm gonna leave it right there after repairing the weld on the intake. I honestly didn't even get a chance to advance timing either.
ERU performance (Engines R Us) long block with custom ERU Pistons made by Wiesco
ported head
BC STG 3 cams
JWT Cam gears
11mm L19 head studs
6766 twin scroll turbo
Fuel Injector Development 2000cc injectors
ECU Master Standalone flex fuel setup for sequential injection and ignition
Twin Walboro 450 fuel pumps
ATI Dampener
Kenne Bell Boost a Spark
OS Giken Triple disc
Z32 tranny
Stock water pump, a/c, & power steering
Here is the dyno video:
https://youtu.be/DYO3tYf8fkc
Here is what the intake looked like after that pull.
842whp KA-T
"Anyone can make power but how long can you make it last?"
duncan351 is offline   Reply With Quote
Old 12-04-2016, 06:47 PM   #2
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
As your sig says, anyone can make power, but apparently it only lasts a 843hp dyno run... lol
Needs more in depth information on this vehicle, this is kind of bland info.
There may be more left in that engine but that turbo is generally only rated for mid 900's
Anyway, I do enjoy seeing another KA being utilized
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 12-04-2016, 06:58 PM   #3
Koukiii
Koukiii is an unknown quantity at this point
Wow nice nice numbers on a KA. I'm heavily consiering running ECU Masters on my next build.
Koukiii is offline   Reply With Quote
Old 12-04-2016, 06:59 PM   #4
duncan351
duncan351's Avatar
What more in dept info are you looking for sir?
842whp KA-T
Old 12-05-2016, 07:40 AM   #5
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
Real life Fast and Furious!
Frank_Jaeger is offline   Reply With Quote
Old 12-05-2016, 07:58 AM   #6
duncan351
duncan351's Avatar
I have caught Soooo much grief over the dam welds braking on the intake
Its fixed now and I'm very happy with the numbers. I will retune the car again some day in the high boost area and see what I can really squeeze out of this motor. I currently have almost 5K miles and motor is doing great.
842whp KA-T
Old 12-05-2016, 08:22 AM   #7
lunchmeat
lunchmeat's Avatar
Just get a danger sticker, slap it on the manifold, and run with it.
lunchmeat is offline   Reply With Quote
Old 12-05-2016, 08:33 AM   #8
turbo2nr
turbo2nr's Avatar
Impressive, Glad to see you're still in the game doing big things. how much power are you shooting for after you fix the intake?
s14 kouki ka-t
Old 12-05-2016, 09:03 AM   #9
duncan351
duncan351's Avatar
Intake is fixed and I'm just driving the car enjoying myself with it. I was at mid 500's for 5+ years. Its a total different world driving at 700 daily. I will do it eventually but to be honest it has been a drain on the bank account to get the car to this point reliably. I took the car on a 5 hour trip out of town and beat the piss out of then drove back 5 hours last week with no issues. So 843 is good for now. I will try to break 900 mark one of these days but with Eagle rods I'm a little concerned. There are so many misunderstandings and misinformation on E-85 it is not even funny. Man be very careful who you listen to and what you read. None of it was correct for my setup however I will say I am 10.5:1 compression so I'm closer to the edge of the E-85 fuel but wouldn't trade it for the world. The torque is great and the response is awesome even with my intake.
842whp KA-T
Old 12-05-2016, 09:20 AM   #10
Highway Riding
Highway Riding is an unknown quantity at this point
Very impressive that's for sure. Cheers
The Sun Rises in the East!
Highway Riding is offline   Reply With Quote
Old 12-05-2016, 09:34 AM   #11
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Can we see a full dyno graph?? The video unfortunately showed a very low quality image without the RPM plot.
Great work BTW!
Old 12-05-2016, 11:21 AM   #12
duncan351
duncan351's Avatar
Great work BTW!
I forgot to clamp the dyno pick up signal to the coil pack wire after regapping the spark plugs but the dyno still recorded the pull. Here is a dyno pull at 33psi which made 761whp.
842whp KA-T
Old 12-05-2016, 12:06 PM   #13
Koukiii
Why do you say 10.5:1 is bad for your setup? Obviously its a compression that needs to be ran with e-85/Race gas for high boost but other than that it should be great all around
Old 12-05-2016, 01:09 PM   #14
KAT-PWR
KAT-PWR's Avatar
Okay Dunc, good to see you on zilvia.
I'm guessing because cylinder pressures and his continued head light issues?
MRP Manufacturing
Old 12-05-2016, 01:43 PM   #15
duncan351
duncan351's Avatar
yea, its really the cylinder pressures and adjusting the timing properly. I finally cured my head lifting issues by using washer inserts. But I detonate on E70 fuel compared to E80 and higher. I have heard so many posts and people say " I run the same boost and timing regardless. It doesn't matter." Maybe because they are all low compression motors. I can only speculate. But for my high compression motor. I had to pull 5* timing out of the motor to keep it from knocking and even then I just stopped at 23psi. Don't feel comfortable trying to push the motor any more on such crappy fuel. Once the summer blend is back. I have no issues with knock. All honesty if I had to do it all over I would have gone 9.5:1. Gives you cushion for knock thresh hold.
842whp KA-T
Old 12-05-2016, 03:23 PM   #16
spooled240
spooled240's Avatar
Looks like you're making power all the way to 7500rpms which is pretty impressive for a KA. Are there any other mods that you didn't list that helped you accomplish this? Are you still using the stock crank?
spooled240 is online now   Reply With Quote
Old 12-06-2016, 05:52 AM   #17
d_nice
d_nice's Avatar
good power here man.
Old 12-06-2016, 07:11 AM   #18
KAT-PWR
KAT-PWR's Avatar
It's not really that uncommon even without the ATI damper (which is common for going passed 7500. Big cams, big revs.
MRP Manufacturing
Old 12-06-2016, 07:53 AM   #19
spooled240
spooled240's Avatar
I guess a built head and aftermarket intske manifold can go a long way. But I've always heard the stock crank starts producing bad vibrations past 7k. This is where the whole hcw vs fcw crank debate began..
Sent from my SM-G935T using Tapatalk
Old 12-06-2016, 11:01 AM   #20
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
Harmonics are a bitch...
My SR20VET
Old 12-06-2016, 12:23 PM   #21
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Post pics of your set up
Old 12-07-2016, 02:16 PM   #22
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
what are your wheel specs? how much stance do you have? how many followers?
just kidding. this is badass.
Old 12-09-2016, 05:35 PM   #23
duncan351
duncan351's Avatar
842whp KA-T
Old 12-09-2016, 06:40 PM   #24
Bushido
Bushido's Avatar
wow! nice #'s
Old 12-19-2016, 11:51 AM   #25
Koukiii
yea, its really the cylinder pressures and adjusting the timing properly. I finally cured my head lifting issues by using washer inserts. But I detonate on E70 fuel compared to E80 and higher. I have heard so many posts and people say " I fun the same boost and timing regardless. It doesn't matter." Maybe because they are all low compression motors. I can only speculate. But for my high compression motor. I had to pull 5* timing out of the motor to keep it from knocking and even then I just stopped at 23psi. Don't feel comfortable trying to push the motor any more on such crappy fuel. Once the summer blend is back. I have no issues with knock. All honesty if I had to do it all over I would have gone 9.5:1. Gives you cushion for knock thresh hold.
Ah yeah I hear you on that. That's why I will only run my car on E-85 with a flexfuel capable standalone. Can't trust what the pump says.
Old 01-06-2017, 07:55 AM   #26
S14Serge
S14Serge's Avatar
S14Serge is an unknown quantity at this point
Congrats on the badass numbers man!
S14Serge is offline   Reply With Quote
Old 01-06-2017, 08:14 PM   #27
RB2.5
RB2.5 is an unknown quantity at this point
Impressive!
RB2.5 is offline   Reply With Quote
Old 04-27-2017, 07:22 PM   #28
jabadboy77
jabadboy77 is an unknown quantity at this point
Numbers are amazing
jabadboy77 is offline   Reply With Quote
Old 05-13-2017, 04:23 PM   #29
Guard1an
Guard1an is an unknown quantity at this point
Mother of God that's impressive man, dare I ask the cost so far ?? Lol
Guard1an is offline   Reply With Quote
Old 10-14-2017, 07:04 PM   #30
duncan351
duncan351's Avatar
Honestly I stopped counting years ago. If I want power and want it reliably I spend the money. You can't get performance and be able to drive across the country without spending some serious coin. Its worth every penny.
842whp KA-T
