Old 12-12-2012, 10:23 AM   #1
smokin-kp61
smokin-kp61's Avatar
smokin-kp61 is an unknown quantity at this point
5spd. swap issues
Just got don't doing a 5 spd swap in my s13 vert the car runs rough now sounds like its missing won't rev up easily is it cuz of auto ecu? Also have another issue when I take out of reverse then into first with clutch pressed down I get a grinding noise but car shift smooth thru all gears clutch petal is very very light sounds like pressure plate to me? Has anyone had these issue just to confirm my thoughts were correct any input thx
smokin-kp61 is offline   Reply With Quote
Old 12-12-2012, 01:14 PM   #2
zerodameaon
zerodameaon's Avatar
Its not the Auto ECU unless it just went bad on you. You can keep the AUTO ECU with no ill effects, and I had the same grinding on my vert until I put in my 1pc drive shaft, don't know why that would make it go away but it did.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
Old 12-12-2012, 02:20 PM   #3
smokin-kp61
Thats really odd ok worth considering
Old 12-12-2012, 05:30 PM   #4
edlover714
edlover714's Avatar
edlover714 is an unknown quantity at this point
i have vert over 5yrs now , 5spd was first thing i did. did u replace clutch with new, new slave cylinder, and master? is tranny hi milage,used trannys all have very worn synchros will cuase a grinding prob eventually. if u didnt bleed system good enough cuase it to grind. bleed system again and if u have used slave cylinder pull boot back to see if its leaking inside. as far as running bad, check for vacum leaks and hoses not cracked on intake
edlover714 is offline   Reply With Quote
Old 12-12-2012, 06:12 PM   #5
smokin-kp61
All used parts but clutch and slave In gunna try to.bleed again ill check vacuum maybe I broke/knocked one off when I was doing bellhousing bolts
Old 12-13-2012, 05:49 AM   #6
Kevin920415
Kevin920415's Avatar
Kevin920415 is an unknown quantity at this point
I read up on some threads on how people ran AUTO ecu fine...
but personally I switched out to Manual ECU and it ran better than auto ecu..
I was having 1500rpm and etc.. and popped in the manual ecu and car was normal lol..
You drive DA 2 fo tay?
Kevin920415 is offline   Reply With Quote
Old 12-13-2012, 02:33 PM   #7
zerodameaon
Do you mean idling at 1500rpm? If so that could have been because you did not adjust your idle. Mine did the same thing until I retimed the car and adjusted my idle down to 700.
