Old 05-17-2015, 07:53 PM   #1
Sr20probs
Sr20probs's Avatar
Sr20probs is an unknown quantity at this point
SR Sr20det cranks no starts but backfires
Sr20det crank no start backfires
-has fuel
-has spark
My sr20det cranks and cranks sometimes backfires but refuses to start I have a orange spark coming from the plugs I know that won't allow it to start but I'm sure there's more to it. My ignitor chip is just connected to the connectors but not grounded. Could that be a issue? Thanks
Sr20probs is offline   Reply With Quote
Old 05-17-2015, 08:44 PM   #2
jscherf92
jscherf92 is an unknown quantity at this point
Ground everything. Check timing. Check compression. Shit is basic.
jscherf92 is offline   Reply With Quote
Old 05-18-2015, 04:59 AM   #3
Sr20probs
Sr20probs's Avatar
I'm going to check all the grounds and reset the timing I know it's basic but I bought the car like this so I I don't know how it was before. I'm gonna start from there I guess. Thanks
Old 05-18-2015, 05:02 AM   #4
Sr20probs
Sr20probs's Avatar
the compression is fine one cylinder is slightly below spec but there all pretty much fine. I have a feeling it's either the grounds or the timing of that doesn't work il be back on here. Thanks
Old 05-18-2015, 08:53 PM   #5
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
Re-stab your CAS. Sounds like it's 180 off
Old 05-19-2015, 05:05 AM   #6
Sr20probs
Sr20probs's Avatar
I'm gonna try that any idea how to do that?
Old 05-19-2015, 05:55 AM   #7
loptosyu
loptosyu is an unknown quantity at this point
loptosyu is offline   Reply With Quote
Old 05-19-2015, 10:22 AM   #8
Sr20probs
Sr20probs's Avatar
Yes I know it sounded stupid. I'm gonna test the compression when I get home if it isn't raining then remove the CAS and line up the timing. I'll see how that goes.
