10-29-2015, 11:20 AM | #1 |
Power steering question
So I have an 89 hatch with oem steering rack (sohc) and I recently swapped it with a sr blacktop, with no power steering lines. Car came with The PS delete and now I want power steering, the question is can I run the oem s14 lines in my s13. Or do I have to strictly use s13 lines. Thanks
11-16-2015, 12:14 PM | #3 |
you need a dual cam high pressure line. (from pump to rack, the whole thing)
im not sure if s14 will work but s13 works. the sohc ps pump is on the right side. when the dohc ps pump is on the left side, just like the sr pump being on the left side |
