Old 12-06-2009, 03:59 PM   #1
boske
boske is an unknown quantity at this point
is this right? coilover question
Alright, I think I have this right but I'm not sure. I got this set of Tein HA s13 coils a year ago and took them apart right away to paint them, since then they have sat in a box in pieces but now I need to install them. The two circled seem to work but the heavy spring is on the back, and that doesn't make sense to me since the weight is mostly up front I would think. The reason they fit this way is because of the threaded collar fits to the spring, but I bought these used so who knows if they were right to begin with. I hope someone can help
boske is offline   Reply With Quote
Old 12-06-2009, 04:06 PM   #2
boske
looks like the threads are 2mm bigger up front, so I guess the collars can't be flipped.
Old 12-06-2009, 04:10 PM   #3
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
larger springs in the front. Smaller springs in the rear with the helper springs.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 12-06-2009, 04:45 PM   #4
boske
I just checked to make sure, the rear collars won't fit up front. I can put the big springs up front but the small springs wont fit the collars in the back, they DO fit just fine up front though, like they are in the first pic.
Old 12-06-2009, 04:52 PM   #5
DreamN
DreamN's Avatar
Trader Rating: (54)
Helper springs go on the bottom of the main spring.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 12-06-2009, 04:57 PM   #6
DreamN
DreamN's Avatar
Trader Rating: (54)
My apologies, forget what I mentioned earlier. Not sure why I thought they were reversed.
Here's an image of how they're suppose to be.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 12-06-2009, 04:57 PM   #7
boske
the springs rub the threads, and the aluminum spacer won't go over the threads. I think tein stuff is just weird, also these coilovers are probably very old, I bought them used from japan on ebay.
Old 12-06-2009, 05:02 PM   #8
boske
thanks for the pic! I think my springs were missing the front helpers and the ones I have go on the back, thanks for the help.
Old 12-06-2009, 05:16 PM   #9
boske
well hold on, the aluminum spacer for between helper/main spring will not slide over the threads of either the front or rear strut, I can't put the helper on the bottom but it should work up top for either front or back, maybe an old design? Is there a problem with having helper on top?
Old 12-06-2009, 07:37 PM   #10
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
then the helper spring wouldnt be doing its job, would it?
lexus baby
5t341tH is offline   Reply With Quote
Old 12-06-2009, 10:11 PM   #11
boske
I thought the helper spring was there to take up the extra space when the suspension is extended, like when the car is jacked up. I don't see any difference, top or bottom. Right now I'm pretty sure I'll need all the helper springs, the rear will only go so low before falling out of the upper mount when its jacked up, anyone have an extra set laying around?
