Old 04-03-2009, 06:31 AM   #1
silviaz
silviaz's Avatar
silviaz is making his/her stupidity well-knownsilviaz is making his/her stupidity well-knownsilviaz is making his/her stupidity well-knownsilviaz is making his/her stupidity well-knownsilviaz is making his/her stupidity well-known
KA/SR swap interchangeable parts guide
I'm doing a little list of parts we can use for the engine swap. Feel free to post what you are 100% sure, then I'll post it in the S13 FAQ thread.
Tranny
1. lower shifter boot
2. gasket boot
3. oem bearing (clutch+flywheel to verify) NOT 100% SURE, my sr beraing was different with my KA.
4. speed sensor
5. Tranny mount
6. Tranny, but it needs the SR bellhousing.
Engine:
1. Powersteering hose
2. KA/SR rad but it needs a new upper hose or some modification
3. Powersteering hose
4. Motor mounts
5. KA24E MAF only
6. Alternator (with some fitting)
7. Water temp sensor
silviaz is offline   Reply With Quote
Old 04-04-2009, 11:15 AM   #2
silviaz
silviaz's Avatar
i'm sure there is more....
Old 04-04-2009, 10:25 PM   #3
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
sorry there are threads about this already. and websites. and books. and dvds.
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 04-04-2009, 10:34 PM   #4
kidego430
kidego430 is an unknown quantity at this point
alternator if you drill out the pivot hole a little bit
kidego430 is offline   Reply With Quote
Old 04-05-2009, 07:54 AM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Since when did SR/KA clutch and flywheel interchangeable?!?!
Oh yah thats right, never...
CLICK HERE!!!
Old 04-05-2009, 08:21 AM   #6
silviaz
silviaz's Avatar
This is WHY i've made a thread about this. I took all theses information right from this section, even in the sticky s13 tech thread. BTW, I did alot of reseach and nothing is clear.
So if you have any REAL info, i think at this time this is a necessity.
Old 04-05-2009, 11:08 AM   #7
awesomenick
awesomenick's Avatar
Trader Rating: (33)
awesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfection
Feedback Score: 33 reviews
You could use a KA clutch disk, and SR flywheel and pressure plate. LOL.
awesomenick is offline   Reply With Quote
Old 04-05-2009, 12:28 PM   #8
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
I used my KA P/S pump with the SR's P/S pump bracket so I didn't have to bleed the P/S system... Not sure if you can do that on the S13's engine though.
My SR20VET
Old 04-06-2009, 11:28 AM   #9
silviaz
silviaz's Avatar
as stupid as it sounds, if this information is correct, I find it useful. Sometime, you have some parts laying around and you wanna run your car as long as it'll do the work.
Old 04-11-2009, 11:40 PM   #10
Odysseus
Odysseus is an unknown quantity at this point
So a stock SR MAF will fit on a SOHC KA? What about stock SR injectors?
I want my buddies stock SR parts haha
Odysseus is offline   Reply With Quote
Old 04-16-2009, 10:03 PM   #11
silviaz
silviaz's Avatar
Injectors are not interchangeable, you'll have to reprogram ur ecu.
Old 04-17-2009, 08:40 PM   #12
silviaz
silviaz's Avatar
USDM SR20DET PART:
T25 Turbo gaskets '90-'95 300ZX TT T25 gaskets (note turbo to O2 housing gasket does not fit on S13 T25)
O2 sensor '87 300ZX Turbo
Ignitor chip '95 Q45
Fuel Injectors '95 300ZX TT (purple plugs)
Fuel Injector Seals '95 300ZXTT kit
MAF '89-'90 SOHC 240SX
Tranny rear main seal '93 240sx
Slave cylinder '93 240sx
T.O. bearing '93 240sx
Pilot bearing '93 240sx
Clutch 89 Nissan Maxima 240mm 9-7/16" spline 24x1
Belts (PS, AC, alt) Gates K050370 Alt. K040345 PS & AC
(Dayco belts - 5050370 ALT, 5040345 PS)
Spark Plugs NGK BKR7ES11 or BKR6 (hoter plug)
Coil Packs '90-'95 300ZX or '95 newer Maxima
S14 SR Oil Filter '95 Sentra SE-R
S13 SR Oil Filter '91 Sentra SE-R
Fuel filter '90 300zx TT
Front and Rear main seal '91 SE-R
TPS '95 KA TPS will work with some soldering
Temp sensor S13 or S14 (depending on chassis not motor) KA24DE temp sensor
Thermostat '91 Sentra SE-R
Radiator cap '90 300zx TT (slightly more pressure for better cooling over stock cap)
Knock sensor '95 240sx
Oil pressure sender '95 240sx
The only parts you really need to get from Japan are the starter, alternator, water pump, and headgasket.
Old 01-12-2013, 04:32 PM   #13
da man
da man is an unknown quantity at this point
Originally Posted by silviaz View Post
USDM SR20DET PART:
i know this is really old but dose anyone know if the s14 KA TPS work on an S14 NA SR (sr20de)
da man is offline   Reply With Quote
