Old 05-01-2008, 10:53 AM   #1
juice.def
juice.def's Avatar
juice.def is on a distinguished road
sub frame rattle?
so on my s14 i have a rattle that after jacking up the back of my car and listening while the wheels are turning sounds like its coming from the rear sub frame bushing on one side. has anyone ran in the same problem? if so will those sub frame spacers help with that rattle or am i stuck having to replace the whole bushing??
juice.def is offline   Reply With Quote
Old 05-01-2008, 11:01 AM   #2
garbury
garbury is making a name for him/her selfgarbury is making a name for him/her self
You could get a clunk from broken subframe bushings, but I had a rattle in my s14 that wasn't those. There are the dampener boxes towards the very front arms of the subframe. They are little metal blocks held in place by rubber arms and when one of the arms breaks, you get a lot of rattling. Make sure its not those because they are easily removeable.
For the subframe, collars are a bandaid. I replaced the bushings with z32 subframe bushings from energy and I like them a lot. Of course, swapping out bushings is a lot more than just adding the spacers.
garbury is offline   Reply With Quote
Old 05-01-2008, 11:04 AM   #3
juice.def
juice.def's Avatar
kool i check it out kuz its a pretty bad rattle only when im on a bumpy road or accelerating fast. replacing those sub frame bushings is just something i wasnt looking forward to doing hhaha
Old 05-01-2008, 02:28 PM   #4
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
than get solid subframe collars to fill in the worn out bushings
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 05-02-2008, 02:50 PM   #5
juice.def
juice.def's Avatar
got it fixed it was that little metal box on one side. good lookin out zilvia comes through again
