Old 09-20-2008, 09:56 AM   #1
N97746
N97746 is an unknown quantity at this point
S13 front strut assembly
When reassembling the front strut, how is the upper spring seat (tophat) oriented in relation to the strut itself. My crappy Chilton manual says the small notch in the upper seat faces the OUTSIDE of the car. this seams to really skew the spring when assembled. When the notch faces the inside it appears that the seats line up better.
Can anybody tell me for sure? RDM you out there? Thanks.
BTW putting GF210s on AGXs.
N97746 is offline   Reply With Quote
Old 09-20-2008, 01:56 PM   #2
N97746
Problem solved. When in doubt track down the FSM. Notch goes to the inside. Chiltons tells you the exact opposite.
