For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
06-15-2011, 05:30 PM | #1 |
FS, Spec Clutch, flywheel, Gt28rs, S13, C&R radiator, Harness, ecu, Sr20det parts
I live in Raleigh NC. I can ship any part. I have paypal and am a verified seller. Ive been on zilvia for a long time. If you have any questions on parts feel free to email me, pm or text me. 919-749-6261.
S13 Euro coupe taillights with s13 light housings in them, good used condition, $50 plus shipping Z32 maf sensor. The first metal screen was removed for better flow. Has the harness with cut wires and a cold pipe with 3inche to 2 inch coupler. Also has a filter adapter on the end. Pretty much plug and play for an sr or ka swap. $100 By flashorlightning at 2011-06-15 Lower intake from a blacktop s13 sr20det with iacv still attached. $75 plus shipping By flashorlightning at 2011-06-15 Full chasis harness from the front to the rear. Minus engine harness. S13, cant remember if its from a coupe or hatch but it did have power windows. Most of the bulbs are still there. Very intact. $100 obo By flashorlightning at 2011-06-15 Spec clutch SOLD TO JORGE THANKS OBO on everything. C&R radiator. Its for an s14 but can be used on an s13. Its for a jdm motor. It has a 16 inche spawl electric fan and a temp sensor bung was welded on and has a stock s14 temp sensor with wires in it now. It also comes with a C&S filler neck. Its a pretty nice setup definatly not mishimoto. $200 firm plus shipping. This is pretty much the most complete turbo kit for an sr20det s13 engine ever. Its a GT28rs china turbo with an sr stock intake flange, new gasket, SSAC O2 housing, SSAC headers, I have the gaskets for this too. It has a 3 foot long stainless steel oil inlet hose, with all earls fittings, At the turbo it has an earls oil restrictor adapter and earls heat wrap around the oil inlet tube and outlet tube. Even has the stock coolent lines and earls fitting for the block. Well over $1000 in this turbo setup. I want $500 solid. This was just started and ran a couple of times then the motor got torn down. No shaft play. Good to go. By flashorlightning at 2011-06-15 By flashorlightning at 2011-06-15 Ac compressor off a 1998 nissan 180sx, S13. Still had frion in it when it was removed from the front clip, hoses were cut. $55 plus shipping, no wheel play. By flashorlightning at 2011-06-15 By flashorlightning at 2011-06-15 Dohc stock s13 power steering lines. Most all are there. No bolts though. $50 By flashorlightning at 2011-06-15 Stock sr headers with heat sheild. One bolt snapped off. Can be easy outted. $15 ps By flashorlightning at 2011-06-15 S13 double din lower radio pocket with brackets $20 By flashorlightning at 2011-06-15
"Home is where the armor is" Last edited by nassin31spr; 06-16-2011 at 04:13 PM.. |
06-18-2011, 04:56 PM | #8 |
460
2 bump limit. You can start new thread in 3 days.
