Old 09-02-2009, 12:38 AM   #1
stealthsr20
stealthsr20's Avatar
stealthsr20 is an unknown quantity at this point
Just a question to for anyone who owns a Greddy oil pan for sr
So i poked a hole in my pan today moving my motor in my garage and was wondering what the advantages of having a Greddy pan were to the stock. Thanks again for your help Zilvia.
stealthsr20 is offline   Reply With Quote
Old 09-02-2009, 10:45 AM   #2
FRSport.com
FRSport.com's Avatar
FRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura about
Send a message via AIM to FRSport.com
The advantages of having a greddy oil pan is that it is able to hold approx 1 more quart of oil. Also it has baffle plates which reduces oil movement and maintains oil in the center of the oil pan, during hard cornering.
Sincerely,
FRSport.com Team
FRSport.com || 18050 Newhope Street, Fountain Valley, CA 92708 (Map link)
Store Hours: Mon - Fri: 8:00 AM - 6:00 PM PST
[email protected] | 800-321-4747 | 714-515-4001 ext 146
FRSport.com Open Box Clearance Items
FRSport.com Weekly Specials
FRSport.com is offline   Reply With Quote
Old 09-03-2009, 09:35 AM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Its not gonna dent, then push on your oil sump and cause your engine to blow or rod knock to death...
CLICK HERE!!!
Old 09-03-2009, 03:08 PM   #4
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
And it has "cooling fins" on it.... It also has a temp sensor port if you want to install an oil temp gauge.
My SR20VET
Old 09-03-2009, 09:26 PM   #5
4x4le
4x4le's Avatar
4x4le is an unknown quantity at this point
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
Darn, everyone had the pros covered. I wanted to list some of them......
Anyways, some of the cons are some sway bars dont work well with them. I know my whiteline swaybar did not. I now have a tanabe that clears it well.
4x4le is offline   Reply With Quote
Old 09-04-2009, 01:27 AM   #6
stickyrices13
stickyrices13 is an unknown quantity at this point
there are alot more PROs then Cons! one con i know of is that if you like your car super low you may hit the greddy oil pan on bumps and stuff. that happened to my friend.
stickyrices13 is offline   Reply With Quote
Old 09-04-2009, 03:41 PM   #7
jr_ss
Trader Rating: (34)
Tell your friend to raise his car, it's not a low rider...
My SR20VET
Old 09-06-2009, 07:25 AM   #8
fliprayzin240sx
Well here's where opinion changes. Greddy pan will take more beating from being low. Problem is when it has had enough, itll crack. What happens when it cracks? More chance that itll leak and you'd notice.
Now on a stock pan, if it hits something itll dent. You wont know its dented and pushing up on your sump till you blow your engine.
So which ones better? I'd take a cracked Greddy oil pan over a blown engine any day of the week.
CLICK HERE!!!
Old 09-06-2009, 07:53 PM   #9
4x4le
4x4le's Avatar
Yea, and I wasnt trying to say they are loaded with cons or anything. I have one and love it!
Old 09-06-2009, 08:00 PM   #10
steve shadows
steve shadows's Avatar
steve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfection
Send a message via AIM to steve shadows
I would suggest you go with a Tomei now.
The tomei is much better because you cannot strip it as easily
I stripped a couple greddy oil pans in my day.
The tomie design is also stronger and will not crack or allow holes to get punched in it
Like Me on FaceBook !
steve shadows is offline   Reply With Quote
Old 09-09-2009, 03:53 PM   #11
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
/\/\/\ like steve said, since its a cast pan, the threads DO tend to pull out.
best bet is to get one of those drain plugs that has a smaller plug inside of it
or something like this
QuickOilDrainValve.com - the best way to change oil
so you don't have to worry about stripping it.
besides the tomei pan, moroso also makes a pan for sr20
Moroso Nissan Silvia SR20DET RWD Large Capacity Aluminum Oil Pan
if i was going to buy a pan, this is the one i would get. too bad they didn't exist when i bought my greddy pan.
Old 09-10-2009, 09:29 PM   #12
4x4le
4x4le's Avatar
^^ that is sexy!
I stripped out my greddy pan too!
I love the pan, but in hindsight I wish I would have went with another brand.
Old 09-11-2009, 01:51 PM   #13
s14unimog
s14unimog's Avatar
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Send a message via AIM to s14unimog
Geez guys, no need for king kong +2 torque spec. I've done a ton of oil changes with my GReddy pan and haven't had any issues.
Not sure about the other sway bars, or chassis differences, but my Susp. Tech. sway bar doesn't kit it.
4x4le's is on an s13 mines s14
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
