Old 02-25-2014, 08:25 PM   #1
RadicalBumblebee
RadicalBumblebee's Avatar
RadicalBumblebee is an unknown quantity at this point
Relay problem
Long story short, I installed a radio, reconnected the battery and no longer did my tailights, brake lights, or rear and front signal lights work. The relay blew and I need a write up on how to replace it and where to find it because I'm dookie with wires.
RadicalBumblebee is offline   Reply With Quote
Old 02-25-2014, 08:32 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
The first thing you have to figure out is what caused the relay to fry itself. Does you no good fixing it if the problem that caused it is still there.
CLICK HERE!!!
Old 02-25-2014, 08:36 PM   #3
RadicalBumblebee
I'm not really sure what fried it because everything worked literally an hour prior to the radio install.
Old 02-25-2014, 10:38 PM   #4
fliprayzin240sx
So sounds like you fucked up the install. Might wanna double check there before you even attempt to fix the relay.
CLICK HERE!!!
Old 02-26-2014, 06:31 AM   #5
RadicalBumblebee
I've checked and yeah I fucked up somewhere along the line haha, but now everything is correct on the radio harness and I just need to replace the darn relay now which I still don't know how to do.
Old 02-26-2014, 07:58 AM   #6
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
DId you splice the dimmer into the lights that might affect the lights if you messed with that circuit.
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 02-26-2014, 08:56 AM   #7
RadicalBumblebee
No, I didn't touch any wire that wasn't pertaining to the radio
