Old 03-10-2011, 08:29 PM   #1
nsr20detpowered
nsr20detpowered's Avatar
nsr20detpowered is an unknown quantity at this point
12PSI on a T28 Safe for Stock ECU?
hye guys i have a blacktop sr20 with a T28. would it be safe to turn the boost up to 10-13 psi daily? it has a auto ECU btw
nsr20detpowered is offline   Reply With Quote
Old 03-10-2011, 08:30 PM   #2
KaminaSan
KaminaSan's Avatar
KaminaSan is an unknown quantity at this point
Come on man, a quick search would have answered this.
NO.
T25 at 13 psi isn't even safe.
someone in the car is screaming when that deadly t25 spools up!
KaminaSan is offline   Reply With Quote
Old 03-10-2011, 08:42 PM   #3
nsr20detpowered
thanks for the friendly reply
Old 03-11-2011, 07:43 PM   #4
Tunnelvision
Tunnelvision is an unknown quantity at this point
With proper tuning and supporting mods it would be fine.
Tunnelvision is offline   Reply With Quote
Old 03-11-2011, 08:08 PM   #5
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
Turbo it self can handle, not sure if your engine will..
Like the other guy says, need proper tuning and supporting mod is necessary.
Old 03-11-2011, 08:32 PM   #6
s13 drifta
s13 drifta's Avatar
Trader Rating: (105)
s13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enough
Feedback Score: 105 reviews
12 psi is stock boost pressure on Silvias with factory boost solenoid, so 10-12 psi will be fine. Just make sure you have a wide band and boost gauge before upping the boost. I drove my car for 3 yrs at 12psi with a t28 daily, still runs as strong as it did the day I bought it. This is on stock ecu.
PM me for s13 or s14 parts!
s13 drifta is offline   Reply With Quote
Old 03-11-2011, 08:48 PM   #7
zac 3ne2nr
zac 3ne2nr's Avatar
zac 3ne2nr is an unknown quantity at this point
Send a message via MSN to zac 3ne2nr
12psi isn't stock. .5ar is which is like ~7psi. all my silvias with stock solenoids ran this and this one still does.
The t28 will take it no probelm, you should though look into, at the very least, an Adj FPR and going to prob 440s and a SAFC. Those are pretty cheap and you will still be ok.
zac 3ne2nr is offline   Reply With Quote
Old 03-12-2011, 12:29 AM   #8
Silvia716
Silvia716 is an unknown quantity at this point
Can you use a z32 maf on a stock ecu to correct for the increase in boost cuz I want to turn my turbo up too. And the stock psi is 7 .
Silvia716 is offline   Reply With Quote
Old 03-12-2011, 04:19 AM   #9
blksylv
blksylv's Avatar
Trader Rating: (33)
blksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymore
Feedback Score: 33 reviews
at the very least youll need a safc to get the z32 maf to run correctly as it wont with just the stock ecu
there is nothing wrong with enjoying the build. however, we sometimes have to remind ourselves that the build is only one part of the puzzle, and that ultimately - enjoying and driving the car is the number one priority.
blksylv is offline   Reply With Quote
Old 03-12-2011, 10:46 AM   #10
s13 drifta
s13 drifta's Avatar
Maybe your boost solenoid is not functioning properly or wired wrong because factory silvias with boost solenoids are around 11-12 psi stock. The waste gate spring is set at 7psi, this is what you are seeing. So people, stop thinking factory boost levels are at 7psi, you are just running off the waste gate.
S14 T28 turbos reach there max efficiency at around 15psi, but this is not recommended for stock injectors and requires tuning.
Old 03-12-2011, 10:53 AM   #11
s13 drifta
s13 drifta's Avatar
No you can't use a z32 maf without any tuning to correct it. You can turn up the boost without a z32 maf, you really don't need one unless you plan on reaching 300whp. You should be doing more research instead of posting. And once again 7psi isn't stock, this is wastgate pressure.
Old 03-12-2011, 11:00 AM   #12
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
11psi is STOCK for the Silvia. All your solenoids don't work. Ask around, ALOT of them don't work. Its pretty rare you find a swapped SR with a functional, properly installed solenoid. Fucking fuck people. 7psi is the WASTEGATE, take off your solenoid and watch ZERO difference in boost pressure.
Go to 11psi. You will bone stock then. Unless you have other mods like a fmic and turboback exhaust. If you want more, upgrade your injectors cuz the 370s max out quick, and a SAFCII. Shit Im on 8psi t25 and 94% with my stockers, boost creep to 10psi puts them at 100%
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
