Old 10-15-2011, 07:33 PM   #1
manny(ΣAE)
manny(ΣAE)'s Avatar
manny(ΣAE) is making his/her stupidity well-knownmanny(ΣAE) is making his/her stupidity well-knownmanny(ΣAE) is making his/her stupidity well-knownmanny(ΣAE) is making his/her stupidity well-known
s14 motor with s13 transmission?
I wanted to know if you could put a s13 manual transmission on a s14 motor. I currently have have an auto on my s14 and wanted to know if this has been done or can it be done. Also, if it would be worth it. I have never driven a manual car so really dont want to wast alot of money on a new or used s14 transmission just to mess up the transmission.
manny(ΣAE) is offline   Reply With Quote
Old 10-16-2011, 07:38 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Yes you can use the S13 transmission.
CLICK HERE!!!
Old 11-07-2011, 12:56 AM   #3
Driftbandit
Driftbandit's Avatar
Driftbandit is an unknown quantity at this point
Remember the s14 trans has a crank sensor on the upper part of the d/s bellhousing that the s13 doesn't. I'm not sure if you can swap the bellhousings from A/T to M/T but you'll avoid the CEL if you can.
Driftbandit is offline   Reply With Quote
Old 06-22-2013, 08:27 AM   #4
Ravens14
Ravens14 is an unknown quantity at this point
Did anyone have a follow up for this? I'm in the same situation. I have a s13 tranny sitting around and I want to do A trans swap in my s14
Ravens14 is offline   Reply With Quote
Old 06-22-2013, 12:17 PM   #5
georgeasorous
georgeasorous's Avatar
georgeasorous is an unknown quantity at this point
i have a 95 ka with an 89 tranny it bolts right up the only difference is the sensors...
http://zilvia.net/f/image.php?type=sigpic&userid=82229&dateline=136013  6092
georgeasorous is offline   Reply With Quote
Old 06-22-2013, 06:51 PM   #6
Ravens14
It will bolt up. I'm just worried that the missing crank angle sensor won't cause problems
Old 05-05-2014, 10:13 AM   #7
90drftsx
90drftsx is making a name for him/her self90drftsx is making a name for him/her self
Will the sensors from the s13 transmission plug right up to the s14 harness or would am i able to swap the sensors over? I would like to put a s13 auto trans into my 95 auto since its cheaper and easier to find.
90drftsx is offline   Reply With Quote
Old 05-05-2014, 10:29 AM   #8
ShakotanGazelle
ShakotanGazelle is an unknown quantity at this point
Ive heard you can just drill the hole for the cas sensor on the bellhousing, or just find a bellhousing for an OBD2 car.
ShakotanGazelle is offline   Reply With Quote
Old 05-05-2014, 10:33 AM   #9
90drftsx
Thanks i still have the tranny off the s14 its just throwing a CEL because of the transmission. I can swap the bellhousings over. Just wondering if the harness plugs up to the sensors or if i can swap the sensors over.
Old 05-05-2014, 06:37 PM   #10
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
I thought you were inebriated or something but then I realized this is a few years old. I can only hope I become as angry in my time here.
Frank_Jaeger is offline   Reply With Quote
Old 07-04-2014, 10:27 AM   #11
Riff_raff21
Riff_raff21's Avatar
Riff_raff21 is an unknown quantity at this point
Sorry to bump this thread. I'm doing the same thing. Do I have to get a s13 or s14 clutch for the s13 tranny. And how about the T/O bearing and fork, will the s13 one work just fine?
Trying to change the game!
Riff_raff21 is offline   Reply With Quote
Old 07-04-2014, 12:55 PM   #12
ShakotanGazelle
S13 clutch kit will work. They're the same.
