Old 04-13-2015, 09:36 AM   #601
drautomotive.com
drautomotive.com is an unknown quantity at this point
I'm sorry to hear that.
Please shoot us a private message with your order information.
Thank you so much,
Anthony
drautomotive.com is offline   Reply With Quote
Old 04-15-2015, 08:43 PM   #602
EnnEssEnnKAT
EnnEssEnnKAT's Avatar
EnnEssEnnKAT can only hope to improve
Where's the info on the pumps?
EnnEssEnnKAT is offline   Reply With Quote
Old 04-16-2015, 09:54 AM   #603
drautomotive.com
we no longer carry pumps, you may check with fuelpumps.com Thank you and I apologize.
Old 05-13-2015, 04:49 PM   #604
Chubaka
Chubaka is an unknown quantity at this point
Send a message via AIM to Chubaka Send a message via MSN to Chubaka Send a message via Yahoo to Chubaka
Do you have S14 hubs currently in stock??
Chubaka is offline   Reply With Quote
Old 05-13-2015, 05:08 PM   #605
drautomotive.com
Unfortunately, no full set at the moment, only the rear for the S14.
I apologize,
Anthony
Old 05-28-2015, 03:23 PM   #606
thegr8one013
thegr8one013 is an unknown quantity at this point
does the stock studs fit on them? I have arp extended studs that i was going to put on my s13 front hubs but now i want to buy your 5 lug swap and slap my arp extend studs on them. p/n of the arp studs i have are 100-7708
thegr8one013 is offline   Reply With Quote
Old 05-28-2015, 03:44 PM   #607
drautomotive.com
That's the correct P/N for the extended studs, yes. They would fit.
Thank you!
Old 05-31-2015, 12:12 AM   #608
CaTalyst.X
CaTalyst.X is an unknown quantity at this point
Cost for front/rear set for S13 shipped to 97303?
CaTalyst.X is offline   Reply With Quote
Old 06-01-2015, 09:59 AM   #609
drautomotive.com
The cost is $237.50 You can check it on 240sxconversions.com We just remodeled the site over the weekend and should be very easy to use now. Hope you guys like it! Thank you and I hope to see your order soon.
Old 06-02-2015, 11:48 AM   #610
HORShi
HORShi's Avatar
HORShi is an unknown quantity at this point
When will the s14 hubs be back in stock?
http://underworld-jp.com
HORShi is offline   Reply With Quote
Old 06-02-2015, 12:00 PM   #611
drautomotive.com
Within the next couple of months. We'll make sure to announce it here.
Old 06-08-2015, 10:41 PM   #612
laurel4
laurel4 is an unknown quantity at this point
Didn't see this asked anywhere, but will stock S13 bearings fit in these ( I have the S13 version)? Think my fronts are going out after a year and if I can use new OEM bearings I will.
laurel4 is offline   Reply With Quote
Old 06-10-2015, 09:08 AM   #613
drautomotive.com
Hello,
yes! yes they will.
Thank you,
Anthony
Old 06-22-2015, 06:52 PM   #614
laurel4
Do you have s13 fronts in stock?
Old 06-22-2015, 07:39 PM   #615
drautomotive.com
hello, yes, the fronts for the S13 are in stock. http://240sxconversions.com/ Thank you,
Anthony
Old 06-22-2015, 10:13 PM   #616
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
Feedback Score: 92 reviews
Looking for both front and rear s13 hubs are they in stock ?
S-Nation S13 is offline   Reply With Quote
Old 06-23-2015, 09:19 AM   #617
drautomotive.com
Hello,
Yes, they are both in stock. Stock is kept up to date on: 240sxconversions.com
For any stock check please take a look on the site.
Thank you so much,
Anthony
Old 06-29-2015, 04:23 AM   #618
Steven_NISMO
Steven_NISMO's Avatar
Steven_NISMO is an unknown quantity at this point
It's showing me that you can order the S14 front and rear pair on the website but the whole set is sold out. Does that mean they're available?
Edit: Sorry, I see that the front is sold out now. Only the rears are available, right?
Steven_NISMO is offline   Reply With Quote
Old 06-29-2015, 12:31 PM   #619
drautomotive.com
Hello,
yes, that is correct. only the rears are available.
Thank you
Old 09-03-2015, 10:29 AM   #620
13coupe.ericlee
13coupe.ericlee's Avatar
13coupe.ericlee is an unknown quantity at this point
How long are these studs? Because I have close ended lug nuts abs I want to be able to use my lugs still. I hope they are oem length.
13coupe.ericlee is offline   Reply With Quote
Old 09-03-2015, 10:30 AM   #621
Nismo_34
Nismo_34 is an unknown quantity at this point
They are maybe 5mm longer.
Sent from my SCH-I535 using Tapatalk
Nismo_34 is offline   Reply With Quote
Old 09-03-2015, 10:34 AM   #622
13coupe.ericlee
So would you think they will still fit gorilla lug nuts and would you know the thread pitch on these studs? Thanks forthe quick reply
Old 09-03-2015, 10:36 AM   #623
Nismo_34
They should. But I didn't do any exact measuring. I've always had open ended lugs. They are the same thread and pitch as the stock studs
Old 09-03-2015, 10:39 AM   #624
13coupe.ericlee
Okay man thanks i really appreciate it.
Old 09-14-2015, 04:12 PM   #625
ikennrockdis
ikennrockdis is an unknown quantity at this point
i bought these awhile ago when these were $285. one of the rear hubs were unpressed. i emailed if i could get a replacement but was told it would be cheaper if i just get it pressed at a local machine shop. i finally went to a machine shop this week to get it pressed, but unfortunately the machine shop tried to press in the hubs but it didn't work so they told me i needed new bearings. is it possible for me to get it replaced with warranty, if i still have warranty on these? i never bolted these on my car yet either.
ikennrockdis is offline   Reply With Quote
Old 09-14-2015, 04:44 PM   #626
drautomotive.com
Hello,
Please send the purchase information thru DM so that I can check on options for you. Thank you
Old 10-07-2015, 01:08 PM   #627
drautomotive.com
THIS IS AN UPDATE ON STOCK AVAILABILITY:
BOTH, The S14 & S13 REAR / FRONT and COMBO are available for purchase.
Ships same day if purchased by 12PM PST.
Thank you
Old 10-15-2015, 09:15 AM   #628
RB180sxChris
RB180sxChris's Avatar
RB180sxChris is an unknown quantity at this point
I need a F/R set for my s14 non ABS. How much shipped to 08879? Thanks!
TOO LEGIT TO QUIT.....
RB180sxChris is offline   Reply With Quote
Old 10-15-2015, 09:23 AM   #629
drautomotive.com
They are available now for purchase on our site with free shipping for $237.50
Thank you and I hope to see your purchase soon.
Old 11-09-2015, 07:40 PM   #630
steveff
steveff is an unknown quantity at this point
Hey guys I've had my hubs for 4 months and went to swap my knuckles and the bearings just fell apart....... so I'm kind of SOL. Message me and let me know what the warranty information is and how I can get a new set.
Sent from my SM-G925T using Tapatalk
steveff is offline   Reply With Quote
