Old 08-28-2011, 08:02 PM   #1
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
Breather Tank/Swirl Pot question.
Ok, I searched and every thread I found the pics were removed. I just need to know how to route the lines. It's going to be mounted on the passenger fender like most are. My instructions are Japanese of course. No pictures either. So can anyone post pics up of there setup and help out a premie please. Greatly appreciated.
Bought it bc I guess I'm a idiot and can't bleed the system correctly obviously. So anyone care to help me out.
It's a S13 and the engine is a redtop Sr20.
Thanks for any help.
SLiDe_WaYz is offline   Reply With Quote
Old 08-28-2011, 08:11 PM   #2
travypoo
travypoo is an unknown quantity at this point
Send a message via MSN to travypoo
here is my parts shop max swirl pot. bottom port goes to lower rad hose
travypoo is offline   Reply With Quote
Old 08-28-2011, 08:29 PM   #3
Fred Allen Burge
Fred Allen Burge's Avatar
Fred Allen Burge is an unknown quantity at this point
Check out this article, it's boss.
Awesome cooling system article.
Ignore the fact that it's for an LS1, doesn't matter.
Silvia, built 5.3 turbo, 4l80e, [email protected]
Fred Allen Burge is offline   Reply With Quote
Old 08-28-2011, 09:11 PM   #4
SLiDe_WaYz
SLiDe_WaYz's Avatar
Appreciate the reply's. For your PBM setup, bottom goes to the lower rad hose, one is going to the water neck, and the other to the radiator correct? Is the other tank behind there another breather tank as well? I'm guessing from that pic you have no need for a coolant over flow tank with one of these? Sorry for the noobish questions just want to do it right.
Old 08-28-2011, 09:12 PM   #5
SLiDe_WaYz
SLiDe_WaYz's Avatar
And to add your engine bay is BOSS.
Old 08-29-2011, 05:30 AM   #6
Fred Allen Burge
Read that article, it answers that question and more!
Old 08-29-2011, 11:21 AM   #7
s14unimog
s14unimog's Avatar
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Send a message via AIM to s14unimog
I hope Powered By Max doesn't mind but this is pretty clear.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 08-29-2011, 02:57 PM   #8
SLiDe_WaYz
SLiDe_WaYz's Avatar
Damn didn't even see that. That's perfectly clear.
Old 08-29-2011, 05:30 PM   #9
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
Where do people buy the fitting that they usually put in the waterneck?
Old 08-29-2011, 07:36 PM   #10
s14unimog
s14unimog's Avatar
^the water neck? As in the little spacer for a sensor pickup? Stance?
Old 08-29-2011, 09:26 PM   #11
Jtuned_andy
Jtuned_andy's Avatar
Jtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud of
fittings came with my greddy swirl tank
http://home.comcast.net/~skunk.werkz/r32_sig.jpg
Jtuned_andy is offline   Reply With Quote
Old 08-29-2011, 09:38 PM   #12
S14DB
AFC #1
S14DB's Avatar
I drilled mine out to 1/4NPT and put a hose adapter in it.
Old 08-29-2011, 09:38 PM   #13
Mister.E
Mister.E's Avatar
Trader Rating: (53)
ah, that's not a bad idea at all.
Old 08-31-2011, 01:01 PM   #14
s14unimog
s14unimog's Avatar
not a bad idea for what? that schematic seems to indicate the inline tap must be pulled from the "cold" supply. I was just answering what I thought you were asking...
Old 08-31-2011, 01:28 PM   #15
Mister.E
Mister.E's Avatar
Trader Rating: (53)
nah, you reminded me of that stance/DiF waterneck spacer. that would be a great place to place a barb to tap off of.
However, i have a KA and they dont make those for a KA.
Old 08-31-2011, 03:59 PM   #16
S14DB
AFC #1
S14DB's Avatar
I pulled my whole intake manifold off and drilled it out and tapped it to 1/4NPT. Stock hole was just to small to put any decent sized fitting in it.
Old 09-02-2011, 07:03 PM   #17
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I ghetto rigged my KA. I found a brake caliper bleeder that fits the KA. I grinded the bottom out so its a straight thru and used it. It works, not like I'm gonna keep this POS KA forever...
CLICK HERE!!!
Old 09-03-2011, 12:40 PM   #18
s14unimog
s14unimog's Avatar
^sick...
msglngh
Old 01-08-2012, 04:58 AM   #19
Bigalow311
Bigalow311's Avatar
Bigalow311 is not welcome here anymoreBigalow311 is not welcome here anymoreBigalow311 is not welcome here anymoreBigalow311 is not welcome here anymoreBigalow311 is not welcome here anymoreBigalow311 is not welcome here anymoreBigalow311 is not welcome here anymoreBigalow311 is not welcome here anymoreBigalow311 is not welcome here anymore
I received an infraction for keeping this thread in my 'subscribed threads...'
Thanks for letting me see your setup yesterday. I definitely need this mod to help promote effecient cooling. I noticed that SARD makes a similar product:
Sard - Lower Hose Adapter Set & Option parts - Nengun Performance
I like the fact that it's a more compact solution to the MAX product.
Design is Lovehttp://180ronin.com/
Bigalow311 is offline   Reply With Quote
Old 01-08-2012, 07:36 PM   #20
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
I understand how these systems work, but don't understand how so many people have overheating/bleeding issues. My car has been apart a zillion times, as have my other ones...never had an issue.
Edit: ANd that's with more track miles than some cars see on street.
Old 01-08-2012, 07:47 PM   #21
fliprayzin240sx
Thats just the return line. You need that and an actual tank. Thats the part you need to install on the radiator return line to the water pump/themostat housing.
CLICK HERE!!!
Old 01-08-2012, 07:49 PM   #22
fliprayzin240sx
Some engines are just a pain in the ass. SRs were easy to bleed but this damn KA kept getting air in the system. Then throw in that I'm burning coolant somewhere (think HG is slowly dying) so I'm almost always low on coolant.
RBs are just as notorious from what I'm told due to the location of the bleeder. Alot of RB guys I knew in Okinawa swears by swirl pots.
CLICK HERE!!!
Old 01-08-2012, 07:52 PM   #23
Bigalow311
Bigalow311's Avatar
Once a upon a time, I opened up my radiator cap and literally smelled fish. There was rust floating around the coolant. I took measures to flush my block and radiator as well as change to a Nismo T-stat but I believe that I still have rust deposits throughout my block. I will potentially have nice, comfortable places for air to get trapped. The Max breather is a good solution for me to 'be better protected from Mayhem.'
I noticed that after the fact. I have to call Max tomorrow to see how quickly they will have the vortex tanks. That will dictate where I will ship the kit and install it.
Old 01-08-2012, 08:05 PM   #24
dudermagee
dudermagee's Avatar
Oh but it does if you're going LSX
thanks man
Originally Posted by DC Dan MAX USA View Post
Don't wuss out on me.
dudermagee is offline   Reply With Quote
Old 01-08-2012, 08:57 PM   #25
codyace
codyace's Avatar
Trader Rating: (58)
That and the coolant path goes through the manifold and all that. Even still, I don't get how a bleeder tank actually bleeds any better/worse than the OEM sysem. Gotta think of how many OEM cars go forever with the stock junk...without any worry or issue.
Once upon a time I understood how the system worked; I knew better lowering the thermostat opening temp below the ECU's 'point' of being warmed up, and knew that if I had rust in the system that no coolant surge tank on earth would actually bleed the system and take it out.
Cliffs: Fill your system with water, run it, drain it. Rinse/refill/repeat a fwe tims. once the rust is gone, put regular coolant in and be happy
Old 01-09-2012, 06:32 AM   #26
Bigalow311
Bigalow311's Avatar
I'll try to bleed it again since I didn't get a warm, fuzzy that I properly bled it last time.
thanks man
Here's another 1:
OMG My RB is overheating!
Old 01-09-2012, 08:55 AM   #27
delado
delado's Avatar
delado is an unknown quantity at this point
Does anybody sell a proper fitting to replace the bleeder screw on the waterneck? In the diagram, it says that if you don't have it, just cap it of from the pot? Does that make sense?
delado is offline   Reply With Quote
Old 04-22-2013, 01:01 AM   #28
alwyzDTF
alwyzDTF's Avatar
alwyzDTF is an unknown quantity at this point
Would I be able to use this
Stance ST7 Water Neck Adapter Nissan SR20DET
as opposed to cutting up my samco hose?
Or do I need to get a temp sensor fitting with a barb for the lower radiator hose?
just making sure there is a way around cutting my new hose.
alwyzDTF is offline   Reply With Quote
Old 04-22-2013, 05:53 AM   #29
S14DB
AFC #1
S14DB's Avatar
Nope that is for the top fitting to replace taping your bleeder hole.
You need a fitting at the lowest point in the system for the return line. Putting a Temp sensor adaptor in the lower hose is the easiest.
Old 11-12-2013, 10:45 AM   #30
alwyzDTF
alwyzDTF's Avatar
Thanks man, I got it all setup.
I have a new question for you guys.
I got the Greddy can and I'm running the Greddy cap it came with. When I fill up my radiator with what I believe to be the right level of coolant and turn the car on it starts pouring out of the bottom hose of the Greddy swirl pot, so I tightened it down a little more and put grey RTV on it and it still leaks when the cars running. I'm thinking I might need a new cap that opens under less pressure so the coolant can go to my catch can instead of being rejected and forced out the bottom hose of the greddy can (swirl pot). My catch can has barely ANY coolant in it.
Swirl cap opens at 1.3
Radiator cap opens at .9 (pretty sure, have to double check)
Then I thought I could switch the two caps but thought the same thing might happen to the radiator and possibly start blowing coolant out of other weird places.
