Group Buys Dedicated Forum for Group Buys. |
01-10-2007, 11:09 AM | #1 |
Yashio Factory *Group Buy* Go Pink
This Group Buy always does very well... I try to keep stock on most of these parts as well but they sell quick.... So, its Group Buy time Again!!!
Group Buy Ends Jan. 30th e-Brake Spin Knob - $30 shipped (Its not a Shift Knob!!!) 1.3ps Radiator Cap - $35 shipped Water Temp Adapter - $35 shipped Radiator Cooling Panel, S13, 180SX, & S14 Kouki Only!!- $109 shipped 1 - S14 Kouki in-stock now. Water Pump Pully - $139 shipped 3mm/5mm/7mm/15mm Wheel Spacer Set (2) - $216 shipped SUS Down Pipe - $240 shipped Tension Rod Brace - $149 shipped (only about 100 made) Ignition Harness - $200 shipped Okachan Water Temp - $159 shipped Okachan Water Temp w/ 1 Sensor - $179 shipped Okachan Water Temp w/ 4 Sensor - $239 shipped Okachan Water Spray Kit (Complete) - $339 shipped Super Light R Radiator - $469 shipped Super Aluminum Radiator - $580 (shipped) *NEW*YF Accessory Kit (Key Chain, Mini Strap, and Carrying Wipe) - $25 (shipped) Simanchu T-Shirt - $35 (Shipped) Large - XLarge 1 - Large in-stock now. Okachan World Shirts... Eranchu T-Shirt - $35 (shipped) Large - XLarge Eranchu 3/4 Sleeve BaseBall Style - $40 (shipped) Large Only! Eranchu Long Sleeve - $40 (shipped) Large - XLarge When Ordering a Japan Made Shirt you MUST order 1 size larger... so if you wear a US Large, you need a Japan XL. Yashio Factory Shirts are only available in Large and X-Large!! This is a One Time Offer!! Yashio Factory Coilovers - $2200 (shipped) These are HKS Hyper-D Coilovers, re-colored, re-vavled, and re-springed to meet Yashio Factory standards. There is 2 Models available: Yashio Factory Spec has a 9/6 spring rate and is 30 way adjustable. Yashio Factory Spec Plus has a 10/9 spring rate and is 30 way adjustable. These can be serviced by HKS USA!! I personally have a set of the Spec Plus on my S14... they are very streetable on full soft, and full hard you will need a new kidney donor!! Stickers are Not Included on the following Items.... Spin Knob, Rad. Cap, and Water Temp Adapter. I will not sell just stickers! Only orders placed over Rare Trick website will be counted!! Not Gauging Interest or Counting Hands!! Place Orders Here!!! Peace Drew
URAS Last edited by MadScientist; 01-11-2007 at 11:02 AM.. |
01-10-2007, 07:44 PM | #3 | |
does the water temp adapter only work with the yashio digi gauge? or will other ones work also?
01-10-2007, 08:26 PM | #4 |
Those prices include shipping so why are you asking for the price shipped?
Sale: Hello Kitty Horn Button S14 Rear Valences K.Y. Gordon the Thief (Tony Chen) |
01-10-2007, 10:18 PM | #6 |
articdragon192 - Not 100% but the tension rods are the same the only question would be the second mounting point on the Chassis.
Jung918 hella_flushed Team Rootbeer - The Water Temp Adapter is universal... thread is 1/8 PT which is the standard size. Peace Drew
URAS |
01-11-2007, 01:48 AM | #7 | |
01-11-2007, 10:56 AM | #10 |
Jung918 - PT simply means the thread is tapered and gets smaller on the inside. NPT & BSPT... everyone I ask about this I never get a good answer on.. even from GoodRidge. I would have to say its NPT because that is the most common.
PITCH - Yes it has the Yashio Factory Logo w/ Hibiscus... here is a pic. Send payment to P.O.Box 231218: Harahan, LA 70123 scottie - Awsome... yes, Lower Ohm resistance for better increase in Spark. Stock has 6 Volt drop, Tenka only has a 2 Volt drop. Also notice that the spikes are less drastick so you will have a smoother power band. Yashio Factory also mentions that the 4V difference is greater than you expect because in a 12volt system a single Spark plug creates 10000 Volts which is nearly 800 times greater. So basically 4V x 800 means your 12volt system is using 320 Volts less. More power for other systems, reduces back-fire, power gain, and alot of other benifical stuff. Peace Drew
URAS |
01-11-2007, 06:55 PM | #11 |
OMG that key chain....that key chain....OMG,haha its mine....im on my way to raretrick to order now!
You could also bet if I had the money I would order 2 sets of coilovers....1 set used for table legs (with the yashio hood being the other part of the table) and a set for a 240!
"General Motors: Because someone has to make rental cars" |
01-11-2007, 10:55 PM | #12 | |
Oh yeah the Key Chain Set is SOOOO Awsome!! You already know I will have one. I was laughing the entire time I was listing it... Its so perfect!! This is the coolest part on the planet right now!! Peace Drew
URAS |
01-13-2007, 04:35 PM | #15 | |
01-14-2007, 01:30 PM | #17 |
locust13 - Negative on the belt... this was very well discused in the last GB if you want to look it up.
hella_flushed - Its all in love. Yes... send payment to P.O. Box 231218; Harahan, LA 70123 Peace Drew
URAS |
01-14-2007, 01:36 PM | #18 |
so if i have a 1via with s13 redtop which radiator panel do order?
also can i get sticker if i order the spin knob and radiator cap? thanks.
TEAM SUS*PECT |
01-14-2007, 04:01 PM | #19 |
nismornr - The sticker comment is just what YF throws it with the product... I dont order or offer stickers. You have a 180sx face then you need a 180SX Cooling Panel.
Peace Drew
URAS |
01-15-2007, 10:27 AM | #21 | |
Peace Drew
URAS |
01-16-2007, 11:02 AM | #23 | ||
Just looking over the last YF group Buy for Info you guys may be interested in... save you the searching.
Dousan PG laid down alot of info about the Water Temp Gauge and Water Pump Pully... he had one and so do I, so dont be shy about getting eather... info on installing and how to opperate is available... just ask. Water Temp only displays in Celcius but you get use to it fast... it also has a dual staged warning light... I have the first one set at the same temp the Thermostat opens (fixed red lights indicate)... and the second is set for temps over 194 Deg F. (or 90 deg C.) this is when the warning lights will click and flash (sounds like your blinker)... 210 deg F. is a bad # for any car. Quote:
15 days till the Group Buy Ends... I would love to see more cars with YF stuff... I dont care if the Group Buy is nothing but 20 Key Chains... just make it happen so I dont feel like I waisted all this effort. Thank you Drew
URAS |
01-17-2007, 02:53 PM | #24 |
can you guys get the YF valve cover? How much would that be? I'm thinkin about placing a nice sized order since I missed out on the last groupbuy. . .
also, is the cooling panel for S13 with Silvia front end? Lemme know. . thanks. |
01-17-2007, 02:57 PM | #25 |
S15 Valve Cover is Off Limits... Its a core exchange and mainly for YF walk-ins only!!
Cooling Panel is available for 180SX, Silvia S13, and S14 Kouki. Peace Drew
URAS |
01-23-2007, 08:51 PM | #29 |
I suck and every time I try to order it tells me the shopping cart is empty. I know you guys like money, but apparently you have some errant electrons with visions of communism sabotaging the plan.
Can I call and ask for the "Zilvia group buy price" or do I have to speak a secret code? Or can I e-mail or PM? LMK because I want the tension rod braces. Thanks in advance! |
01-24-2007, 10:46 AM | #30 |
KA24DESOneThree - so basically what your saying is... I need to kill one of my Tech guys!!! No Problem... Just call me and order it (504-296-0103)... if I dont answer, leave a msg and I will call you back.
SilviaSR20DET - OK OK fine I will take pics of my Interior... no flaming the Auto Trans... Quangs203 - Yes... But its not part of the GB... if you noticed all the GB parts are small so the shipment can be sent EMS... not Sea Freight. Peace Drew
URAS |
