Old 07-22-2008, 06:02 PM   #1
jyb116
Banned from the Marketplace
jyb116 is an unknown quantity at this point
turbo issue
hey guys i have a issue my sr20det was sounding like a tractor so i looked for an exhaust leak found one, but then i realized it was comming from the top and my turbo was spoiling... so today i took a look at it and i found a gap between my turbo and manifold about an inch, i was thinkin just putting new bolts in please tell me what you guys think ill post pictures in a sec thanks
heres what i found
jyb116 is offline   Reply With Quote
Old 07-23-2008, 01:54 PM   #2
jbuckley
jbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of lightjbuckley is a glorious beacon of light
happens. pain in the ass huh?
with your new bolts try using a lock to keep them from backing out
jbuckley is offline   Reply With Quote
Old 07-23-2008, 06:21 PM   #3
JVD
JVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfection
They're studs, not bolts.
May as well take the whole turbo/manifold assembly off and put a new metal gasket on. Then replace the nuts with these...
http://www.frsport.com/FRSport-Turbi...ut_p_3096.html
JVD is offline   Reply With Quote
Old 07-23-2008, 06:25 PM   #4
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
haha those little suckers are expensive. they work well tho, i bought like 20 of them a while back for my turbo install. they wont back out, just make sure that you put the studs in tight enough and you'll have no problems.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 07-23-2008, 07:50 PM   #5
Sileighty_85
Sileighty_85's Avatar
http://www.thenismoshop.com/ikorb.ph...oduct_id=12721
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-23-2008, 08:03 PM   #6
JVD
Originally Posted by Sileighty_85 View Post
Those things are just annoying. I had that on my shit and it the nuts still backed off. Those come from factory though...so I dunno how tight they were against the nuts.
Still lame if you can just buy the proper nuts for the same price.
Old 07-24-2008, 05:22 AM   #7
Soup Nazi
Soup Nazi's Avatar
Soup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond repute
I just put alittle tac weld on the nuts so that they will never back off.
It's easy to get the welds off as well. I had the same issue. Make sure you get a new gasket.
Originally Posted by sil80forme View Post
Edited u guys suck
Nissanparts.cc... Enjuku-Racing
Ever bought anything from me?
Leave a review
http://www.zilvia.net/f/showthread.php?t=200877
Soup Nazi is offline   Reply With Quote
Old 07-24-2008, 05:34 AM   #8
Sileighty_85
true but easiest to deal with with the turbo and everything off the car.
I still used them with my Peak Perf. Manifold
no problems since
後輪駆動車1番
1986 SR86 - 200ish
Old 07-24-2008, 06:18 AM   #9
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Locking tabs FTW...also change your engine mounts. They probably got loose due the engine torquing sideways too much...
CLICK HERE!!!
Old 08-26-2008, 07:43 AM   #10
ArmadaJspec
ArmadaJspec's Avatar
ArmadaJspec is an unknown quantity at this point
RB
Man this calls for an upgrade! At least get Megan Ex. Manifold $169.00 I know a lot of guys that use their ex. manifold and have had no problems.
and while your @ it Megan 3" stainless exhaust elbow $113.00 they come with all new hardware.
ArmadaJspec is offline   Reply With Quote
