Old 06-30-2008, 08:39 AM   #1
Birdman12
Birdman12 is just really niceBirdman12 is just really niceBirdman12 is just really niceBirdman12 is just really niceBirdman12 is just really niceBirdman12 is just really niceBirdman12 is just really niceBirdman12 is just really niceBirdman12 is just really nice
not going into boost
I have a T3 turbo with a 44mm tial external wastegate (ka24det). i was driving up a hill and boosting fine then when i let off my bov sounded half way and then i heard a ting or metal click noise and now it wont boost anymore...it still runs fine and feel like n/a. i took the wastegate off and took it apart to inspect, spring is good and everything looked fine. i checked for vacum and boost leaks, none. i have no idea what is wrong, turbo is fine and from what i can see the wastegate should be good too. any suggestions? thanks!
Birdman12 is offline   Reply With Quote
Old 07-01-2008, 01:21 AM   #2
Joel 180
Joel 180 has made poor choicesJoel 180 has made poor choicesJoel 180 has made poor choicesJoel 180 has made poor choicesJoel 180 has made poor choicesJoel 180 has made poor choices
skylines make a ting sound when the ceramic exhaust wheel delaminates and goes flying into the cat.
But im guessing you dont have a ceramic turbo...
Joel 180 is offline   Reply With Quote
Old 07-01-2008, 01:23 AM   #3
downshift_sideways
No Limit Soldier.
downshift_sideways's Avatar
downshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfection
Send a message via AIM to downshift_sideways
^what kind of fucking post was that?
That was no what helpful whatsoever. wow.
what is your boost gauge reading at after that happened?
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only"
downshift_sideways is offline   Reply With Quote
Old 07-01-2008, 06:07 AM   #4
Joel 180
if the car isnt boosting youd assume it was zero.
no boost:
wastegate stuck open
blown turbo gasket
seized turbo
broken exhaust wheel
broken compressor wheel
excessive exhaust back pressure
Old 07-02-2008, 08:09 AM   #5
Birdman12
i checked the bov and wastegate both in good working condition and no problems...im going to remove the turbo tonight and take a look at the exhaust side of the turbo and check to see if the shaft is still in one piece :S
Old 07-04-2008, 01:24 AM   #6
golfer17
golfer17's Avatar
golfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nice
Send a message via AIM to golfer17
that's the only thing I can think of at the moment. kinda interested to see if it turns out to be something else, though. Let us know how it goes, this is the first time I've heard of a shaft breaking... I wonder if it could have been heat/lack of oil or if the wheels loosened up enough and lost their balance or...
golfer17 is offline   Reply With Quote
Old 07-04-2008, 06:46 AM   #7
Birdman12
i`m going to check the wastegate again because i was reading some posts on ka-t.org and some guy was asking about the tial external wastegate and he asked if its supposed to be able to spin around while installed and some people said its not supposed to do that and i`m pretty sure mine does...i`ll keep you posted.
Old 07-06-2008, 07:51 AM   #8
Birdman12
i took it apart and tightened down a nut and it doesn't spin anymore.
however, someone told me last night that there is supposed to be a valve seat ring between the wastegate and the manifold....i'm guessing that is the problem and that was the noise because i dont have that ring when i took the wastegate off. but where would have it gone? out the screamer pipe hopefully!
and now to look for a 38mm valve seat at 9:45 on a sunday morning before i have to leave for montreal again
Old 07-09-2008, 08:21 PM   #9
golfer17
golfer17's Avatar
that makes more sense. I've heard of people buying ebay wg's and not having that included so their wg is always open, however, you should still see a little bit of boost if this is the problem. Not sure how it would come off though, that is pretty odd...
Old 07-11-2008, 02:02 PM   #10
Solidus311
Solidus311's Avatar
Solidus311 is making a name for him/her selfSolidus311 is making a name for him/her self
Could it be a boost leak? Check all your intercooler connections.
cardomain.com/ride/3113705
Solidus311 is offline   Reply With Quote
