For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
![]() Join Date: Aug 2006
Trader Rating: (105)
![]() ![]() ![]() ![]() ![]() Feedback Score: 105 reviews
![]() I am parting out a great condition s13 blacktop sr20det. The motor was running well before being dismantled. The reason it was taken apart were intensions of building it to hold more power. I don't have time to build a motor right now, so all parts are up for sale. This entire motor is very clean and no parts are damaged. I have all bolts and small parts bagged and labeled. A lot of parts have been sold, what you see is what I have left for sale.
If you see anything you are interested in purchasing post reply or PM me. All prices do not include shipping, please leave zip code for quotes. Valve cover (one broken tab in rear, good for s13.4 cover)-$50 Blacktop head w/ cam caps, valves, springs, retainers, and seals-$280 OEM cams-$70 for pair Cam gears-$30 for pair Rocker arms-$80 for all 8 Lifters-$80 for all 8 Shims-$20 for all 16 Oil feed tubes-$30 for pair Head bolts w/ washers-$20 for all Timing chain tensioner-$30 Timing chain-$20 Lower timing gear-$10 Rods w/ ends & bolts-$80 all 4 Crank girdle -$30 Windage tray-$25 Upper oil pan-$60 Oil strainer-$20 Rear main seal w/ housing-$15 Oil pump spacer/collar-$10 Crank bolt-$8 Blacktop head (comes with cam caps, bolts, valves, springs, retainers, seals, and valve cover studs)-$280 Crank girdle-$30 Main bolts-$20 Windage tray w/ bolts- $25 Inner baffle w/ bolts-$15 Rear main housing w/ seal-$15 Upper oil pan-$60 OEM cams-$70 ![]() Oil feed tubes-$30 for pair ![]() All bolts bagged and labeled ![]() Timing chain tensioner-$30 ![]() Oil sandwich plate-$30 Flex plate-$40 OEM flywheel-$50 Flywheel bolts-$30 for all 8 Sr20 Exedy stage 1 clutch (lightly used)-SOLD Sr20det transmission w/ all sensors-$290 ![]() Sr20det starter-$80 Coil pack cover (small crack next to O)-$20 Coil packs-$70 for all 4 Coil pack harness-$30 Crank angle sensor-$100 Knock sensor w/ harness-$30 S13 manual TPS-$40 Oil strainer-$20 ![]() Water outlet w/ bolts-$30 ![]() Water inlet w/ bolts-$20 ![]() Thermostat housing w/ bolts-$20 ![]() Temp sensor housing-$20 Temp sensor for gauge-$10 Temp sensor for ECU-$10 Temp sensor harness-$15 S13 water lines-$30 ![]() S13 intake manifold-$50 ![]() Intake manifold brackets-$20 for all ![]() S13 throttle body w/ auto TPS-$50 ![]() S13 IACV-$80 370cc Injectors-SOLD injectors caps w/ screws and washers-$5 each S13 fuel rail-$25 SR20 fuel pressure regulator-$25 Sr20 alternator bracket-$30 Sr20 alternator-$80 Sr20 A/C compressor $70 Sr20 A/C bracket w/ bolts-$30 Water pump pulley-$15 Idler pulley-$15 Dip stick housing-$10 Oil separator-SOLD S13 sr20 boost solenoid and egr sensor w/ bracket-$25 Sr20 AIV-$20 Engine mount brackets-$40 ![]() OEM exhaust manifold-$50 OEM turbo elbow-$20 Goodridge s13 sr20det water return line-$40 S14 sr20det water neck-$50 T28 actuator-$25 T25 turbo water and oil lines w/ banjo bolts-$30 ![]() HKS bov flange w/ 2" pipe-$25 3" down pipe ( used few hrs.)-SOLD Oil feed banjo bolt-$10 T25 oil restrictor-$10 CXracing 2 piece cold pipe (brand new)-$50 Steel cold pipe painted aluminum-$50 ![]() Thanks for looking, let me know if you need anything.
PM me for s13 or s14 parts! Last edited by s13 drifta; 03-30-2012 at 03:15 PM.. |
How much for what? Everything?
Yeah, I can sell one coil pack for $20. Shipping will be $15 to Florida. Total of $85 shipped.
PM me for s13 or s14 parts! |
#23 | |
Thanks, takes time to do it right.
#26 | |
You're welcome, let me know if you need anything else.
#27 |
Do you still have the goodridge water return line? I assume that is a water return line for a T25/T28 SR20DET turbo? I would like this line and am ready to paypal. Need it shipped to 22015.
