Old 11-13-2004, 02:50 PM   #1
s13dan
s13dan's Avatar
s13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enough
240 KA all motor qeustions
OK, i am wanting to build an all motor 240.. if you think this is a bad idea dont reply please... OK first im set on using a KA, but witch on is better SOHC or DOHC..? does anyone actully know? or have had either with uped compression and such. I have heard of people puttin 90 piston is DOHC to get compression to 11.1 and the getting cams and basic bolt on and will produce 200hp to the wheels.. can anyone give me any kind of info? websites or anything...
89 240sx hatch #933-the hot rod
91 240sx coupe #131,603-the daily
s13dan is offline   Reply With Quote
Old 11-13-2004, 05:33 PM   #2
AlligatorBling
AlligatorBling's Avatar
AlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choices
Send a message via AIM to AlligatorBling Send a message via Yahoo to AlligatorBling
Order a catalog from these guys. They have kits that produce insane horsepower for the KA... but you better have deep pockets.
www.paeco.com
AlligatorBling is offline   Reply With Quote
Old 11-13-2004, 06:45 PM   #3
projectRDM
projectRDM's Avatar
89 pistons will net 11.6:1, to high for pump gas. At best with a 11:1 motor and lots of work you'll see about 180-185 rwhp, that's after you drop at least 3k at it.
In other words, not a real benefit for the money.
FORMERLY R240NA
Old 11-13-2004, 07:18 PM   #4
BoroBoroS13
BoroBoroS13's Avatar
BoroBoroS13 is on a distinguished road
Here are a two links I found interesting when considering building a KA.
http://www.racetep.com/240sxna.html
http://home.att.net/~MabuhayCarlos/NA.html
I decided to go CA18 cause my KA wasnt in great shape but if I had a lower milage motor that didnt have such a hard life I may have stuck with the KA. It does have a few good features to it but Im addicted to boost now. Hehehe
BoroBoroS13 is offline   Reply With Quote
Old 11-13-2004, 09:52 PM   #5
s13dan
s13dan's Avatar
Does anyone know if the DOHC is better or SOHC cuz i have heard both...
Old 11-13-2004, 10:22 PM   #6
Rennen
Rennen's Avatar
Rennen will become famous soon enoughRennen will become famous soon enoughRennen will become famous soon enough
Send a message via AIM to Rennen Send a message via MSN to Rennen
What do you want out of your engine?
From this thread and reading your last one, you need to ask yourself what your ultimate goal is for your car/engine. If you just want to show some people up at the drag strip, keep your SR or start a turbo KA. If you want to autocross/roadrace, pick up a rule book and plot out how to modify your engine to the extent of the rules. If you are going balls out NA just because of originality, try the E, there are already race parts and information available from SCCA's GT3 class. If you just need high performance for only daily driving(which I never understood), you will never see the difference between a E and DE.
If it were me, I would figure out EXACTLY what my goals were before throwing money around.
My 2¢
-Matt
FWIW: I plan on building a KA24E up the allowances in SCCA's DSP autocross class(bored .40 over, gasket matched intake/exhaust, side draft carbs, etc.) But it is definitely a long term project, because the engine will be the least important part of the car.
'89 Nissan 240SX fastback: #23 DSP/RallyMod2/Track Slut
'95 BMW 540i 6 speed: Ultimate Commuting Machine
PFM Racing
www.solo2.org
www.midwest240sx.com
Rennen is offline   Reply With Quote
Old 11-13-2004, 10:38 PM   #7
TokyoNights
TokyoNights's Avatar
TokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really nice
Send a message via AIM to TokyoNights
Im in the same boat as you man. I allready have a spare DE and It WILL make 200 at the wheels.
TokyoNights is offline   Reply With Quote
Old 11-14-2004, 12:45 AM   #8
atom
atom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to all
I'd head over to Honda boards or even VWvortex, those guys have had good success with ITB's. You can find a lot of good info there. Check out the motorcycle ITB setups they use on their engines, pretty cheap too (not counting the engine management).
atom is offline   Reply With Quote
Old 11-14-2004, 12:47 AM   #9
raging panda
raging panda is an unknown quantity at this point
Send a message via Yahoo to raging panda
if someone could figure out how to hook up a megasquirt to a KA, then itbs would be good to go.
raging panda is offline   Reply With Quote
Old 11-14-2004, 09:08 AM   #10
sciamop
sciamop's Avatar
sciamop is making a name for him/her selfsciamop is making a name for him/her self
I don't usually recommend this... but judging from this thread and your last one, you should just drop a Chevy 350 V8 in your car.
-- Cheap
-- Powerful
-- NA
-- Insane Aftermarket
-- Parts Galore available in BFN
Todd
93 Coupe
90 Coupe
sciamop is offline   Reply With Quote
Old 11-14-2004, 11:54 AM   #11
s13dan
s13dan's Avatar
im keeping it in the family so only nissan engines, and i dont know where i could get a cheaper engine than a KA that drops right in... i havnt seen a KA go for more than 500$ with tranny.. and as low as FREE.
Old 11-14-2004, 12:00 PM   #12
SR240DET
SR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud of
Send a message via AIM to SR240DET
check nicoclub.com... and when you get there.. search... all the info is there..
SR240DET is offline   Reply With Quote
Old 11-14-2004, 03:57 PM   #13
Dweezil
Dweezil is an unknown quantity at this point
I'd love to build a 240 HP KA. Sure it would be tough, but I'm allways looking for a new challenge. In my mind is what seems to be needed is `90 pistons, knife edge crank, lightweight flywheel, underdrive pully, mild P&P head, minimum of 2 `91 exhaust cams or larger, 370cc injectors, ITBs, hotshot header, 3" exhaust w/ cat, and an e-manage with timing harness to tune it. I'm reasonably sure that with careful assembly and tuning that should get really close to, if not 240 WHP.
It's also likely that the car would barly be streetable like that if at all.
Originally Posted by tah
I would buy myself breast implants so I could play with some titties without getting slapped.
Dweezil is offline   Reply With Quote
Old 11-14-2004, 04:08 PM   #14
AlligatorBling
^ do that, then fabricate a super charger for it
Old 11-14-2004, 04:15 PM   #15
Ghettokracker71
Ghettokracker71's Avatar
Ghettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enough
Send a message via AIM to Ghettokracker71 Send a message via Yahoo to Ghettokracker71
I want a KA24DZE,KA24DER,KA24DES or whatever the fuck is the proper term,too ! !
EDIT: This thread is about all motor KAs though...
Ghettokracker71 is offline   Reply With Quote
Old 11-14-2004, 04:26 PM   #16
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
s2000 drivetrain!
wootwoot is offline   Reply With Quote
Old 11-14-2004, 04:51 PM   #17
MakotoS13
MakotoS13's Avatar
MakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-known
Send a message via AIM to MakotoS13
man, i'd REALLY like a 350Z powertrain
that'd rawk my world... but finding the motor would be hell.
MakotoS13 is offline   Reply With Quote
Old 11-14-2004, 07:33 PM   #18
XxJaPxOxNeEs23xX
XxJaPxOxNeEs23xX's Avatar
XxJaPxOxNeEs23xX is making a name for him/her selfXxJaPxOxNeEs23xX is making a name for him/her self
Send a message via AIM to XxJaPxOxNeEs23xX
can u make a ka have higher rpm horses. so it doesnt punch out all that toque at once.
XxJaPxOxNeEs23xX is offline   Reply With Quote
Old 11-14-2004, 07:45 PM   #19
Dweezil
^ It's all in the valvetrain and if it can support it. Longer duration cams and larger ports will move your powerband higher in the rev range. The nice part about raising the compression is that you can still have torque down low for street driving.
Old 11-14-2004, 08:45 PM   #20
projectRDM
projectRDM's Avatar
Wrong.
Sunbelt Performance gets about 240 out a full race motor (from the Speedvision Touring Cup and ITA type cars), and there's a LOT more work than that involved. Headwork is extensive, full reprogram and heavy tuning, stupid cam profiles, ultra high compression on race gas only, completely unstreetable.
FORMERLY R240NA
Old 11-16-2004, 12:32 AM   #21
97DubTruck
97DubTruck is making a name for him/her self97DubTruck is making a name for him/her self
Find a non turbo s15 motor. Then get ITB's.
Anyway in Kennesaw there is a guy that works on classic Z's and they had a road race s13 in the early nineties that was an 89 coupe with the SOHC that had close to 300 hp at the break. So much work though.
97DubTruck is offline   Reply With Quote
Old 11-16-2004, 12:39 AM   #22
Drunk Bastard
Drunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really nice
Send a message via AIM to Drunk Bastard
damn! 300hp allmotor S13?! I would be happy with 200.
Drunk Bastard is offline   Reply With Quote
Old 11-16-2004, 02:49 AM   #23
driftyour40
driftyour40's Avatar
driftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the rough
Talk to the guy from the drift factory, he might be able to help you. www.driftfactory.com he’s got his own forum, (if you didn't know) and the number to his office is there somewhere on his site . He was running an all motor KA24DE s13 if I remember correctly.
driftyour40 is offline   Reply With Quote
Old 11-16-2004, 10:40 AM   #24
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
if you have the money have everything balanced. like the crank, rods, anything that you can balance, balance it at a machine shop... but i hope you are rich in order to have everything balanced i suggest selling a kidney... but your redline would be higher and faster revving..
s13silady is offline   Reply With Quote
Old 11-16-2004, 12:01 PM   #25
AKADriver
AKADriver's Avatar
AKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura aboutAKADriver has a spectacular aura about
Sidedrafts or ITBs when you can't change the compression or head flow or cam is a BAD idea for the SOHC. If you want to make usable power, things have to be matched. Stick with a ported stock intake manifold for DSP autocross. Four 44mm throttles is super overkill for an otherwise "stock" blueprinted motor. That intake setup was developed for 250+hp engines.
Beyond 200 crank horsepower you reach a point where proper internal work is critical. You can do all the headwork you want and use the most insane cams you can find, but if your engine can't safely spin faster than 7000rpm then you're limited to what you can produce in that rev range. This is why 250hp or more becomes such an arduous task. If you want that kind of power per liter from a rev-limited engine, then you can't just spin it faster, you have to produce more torque per liter... and beyond about 75lb-ft/L becomes extremely difficult to produce for a streetable NA engine. Not to mention, with no variable valve timing, if you've moved your torque band even to the top of our available RPM range you've already got very lopey camshafts.
The good news is, getting up to around 190-200 crank horsepower is relatively simple. The key is proper tuning. I've seen it done with an S14 with nothing more than a short-ram intake, exhaust, stock manifolds, mild cams, and - this is critical - a remapped ECU. Optimizing the fuel and ignition timing for your combination is what makes a car with "bolt ons" actually work. And you DON'T need a standalone to do it, unless you plan on constantly changing and updating your combination... IMO for a streetable engine something like a JWT ECU works just fine.
AKADriver is offline   Reply With Quote
Old 11-16-2004, 04:12 PM   #26
C.
C.'s Avatar
C. is an unknown quantity at this point
what AKADriver said is true. a KA can't safely rev above 7K, so it would be VERY dificult to get that much HP, that said, why don't you just get a sr20de and then install a sr16ve head and then go from there, sounds like a better idea to me.
C. is offline   Reply With Quote
