01-15-2010, 04:23 PM | #1 |
new and a 5lug Q
hey everyone, i own a 1995 nissan 240sx and a 1996 nissan 240sx.
i just bought my 1996 as a doner car 2 days ago and the plan is to swap the ka24de and the 5 lugs to 1995 shell. i am doing this because i bought the 1996 for $900 bucks, but it has been rear ended pretty bad. so my question is. is there a walk through or a guide or a sticky somewhere for a 5lug swap. please tell me you guys have one im tired of searching. and this front hub is kicking my A** |
01-15-2010, 04:35 PM | #2 |
Bandwagon.
for future questions
http://zilvia.net/f/chat/297481-smal...w-threads.html && here you go. http://zilvia.net/f/archive-faqs/142...pics-rear.html && your cars are both s14's just need to swap out the spindles/hub etc. bolt on manggg |
01-15-2010, 04:38 PM | #3 |
yeah i know what needs to be swapped, just havin a problem removing the 4 lugs from the 95, just wanted to make sure my car knowlage is correct.
and thanks for the info, maybe stick around on this site for awhile and post my build thread sometime. |
01-15-2010, 09:10 PM | #4 |
i did the 5lug swap recently and its not hard at all
just unbolt any arms attached to the front spindle, and replace the spindle with the 5 lug one the spindles are identical but S13 use 12mm bolts and S14s use 14mm bolts on the strut you might have to hit the spindle a couple of times with a hammer to slide the arms out. |
01-16-2010, 12:11 AM | #5 |
Remove 4lug hubs.
Install 5lug hubs. This is all very remedial, basic stuff. Asked and answered for over a dozen years.
01-16-2010, 10:36 AM | #6 | |
and just so you guys know all 4 luggers are off now, bout to pull and place the 5 lugs. and looking it over and the 2hours it took to pull its pretty simple and self explanatory. thank you guys again for the help |
