Gauge cluster and tail lights won't light up
Hey guys,
I recently just changed all my fuses and everything worked fine and then a couple days later they went out again. I have changed the fuses and I have checked all the others. The thing is is i tried a different relay and everytime I turn my headlights on it sounds like a light switch clicking. I have searched and all them say the same thing, but nothing about a relay. Any help would be appreciated. Thanks Zak |
![]() Join Date: Jan 2008
I had a similar problem once, turned out to be the 75a alternator fuse in the engine bay. I tried changing all the other fuses, and it worked sporadically but that fuse was the permanent fix..
'89 240sx-Track monster in progress '03 Grand Prix GTP-pepped up DD. |
If it was the alternator fuse then none of gauges or accessories would work. But i had a same exact problem and mine turned out to be the rear lights fuse. Replaced that and everything was back to normal!
This. Had the same problem in more than one car, same culprit.
![]() Join Date: Aug 2008
^The same thing happened to my S13 about two years ago. I couldn't figure out what was wrong. Took it to an elec. specialist, he called me later the same day to tell me the white elec. box behind the driver's side kick panel had gone bad. OP, your issue sounds like a bad connection causing a short.
![]() Join Date: Sep 2011
almost the same thing with my vert but my rear light are the problem with me they shut down randomly and i kept on replacing my fuses and it went go after 3 weeks later my whole fuse box in side the kick panel started smoking about to catch fire so i just turn of my car and waited a while then turned it back on and its back to normal just my fuse box is all burned up i need to change it asap!
