Old 07-02-2010, 10:41 AM   #1
anfitch2k5
anfitch2k5 is an unknown quantity at this point
Oil restrictor question!
yes, i have searched and searched, cant find anything to help with my current situation.
first off i have a s13 blacktop sr20det, came with stock t25 and hard lines. no restrictor needed. well then i got a s15 turbo and a buddy of mine had lines for it but i knew it needed a restrictor so used his off the s14 sr with the factory s14 sr banjo bolts and factory s14 sr hard line. the factory s14 sr banjo bolt that goes into the block has a restrictor built into it correct?
well now im about to run a 2871r adn i bought new CS lines and a new restrictor. so my question is would i be "double restricting" my new turbo with the factory s14 sr banjo bolt into the block and the restrictor from enjuku racing recomended for the stainless lines and BB turbos?
do i just use one or the other?
both?
use the restrictor that screws into the turbo and find a different banjo bolt that goes into the block thats not restricted? am i wrong in any of this? any info would help!
anfitch2k5 is offline   Reply With Quote
Old 07-02-2010, 11:01 AM   #2
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
just buy this
Pegasus - Male 12 x 1.25mm Metric Convex Seat to 3AN Male, Steel
and use the -3AN braided line from it to the restirctor.
and get rid of the banjo bolt buisness.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 07-02-2010, 01:56 PM   #3
anfitch2k5
Is that the correct thread pitch for the oil feed on the block? And I wouldn't need to use a washer or would i?
Old 07-02-2010, 02:00 PM   #4
japslapsilvia
yes it is the correct fitting (thread pitch and size)
yes you will need to use some sort of "crush" washer.
im currently using this fitting and a crush washer.
Old 07-02-2010, 02:41 PM   #5
anfitch2k5
Thanks man! I'll order it tonight! Apprechiate it
Old 07-03-2010, 09:12 AM   #6
anfitch2k5
okay im still wondering if i was double restricting my turbo.. s14 banjo bolt oil feed line and a restrictor from ATP turbo.
Old 08-26-2010, 10:13 PM   #7
Options13
Options13's Avatar
Trader Rating: (43)
Options13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the rough
Feedback Score: 43 reviews
shit!! no more in stock!
Options13 is offline   Reply With Quote
