Old 01-29-2012, 12:10 PM   #1
USAFKOUKI
USAFKOUKI is an unknown quantity at this point
s14 Passenger Window whisteling...ugh
Mods: If this is in the wrong section I apologize, please move as needed.
So I drive my 240 on the highway alot, and recently my passenger window has started whisteling when I'm going 70 or faster> Just started doing this recently and dont know why. Ive wondered if installing the jdm rain guards would keep the air from hitting where the window meets the rubber, and stop the noise. Thoughts? is a kouki btw, Thanks!
USAFKOUKI is offline   Reply With Quote
Old 01-29-2012, 12:13 PM   #2
qwerth
qwerth's Avatar
Trader Rating: (25)
qwerth is an unknown quantity at this point
Feedback Score: 25 reviews
sure all the weather stripping is all there?
hopefully you can just replace it if thats the problem
qwerth is offline   Reply With Quote
Old 01-29-2012, 12:15 PM   #3
USAFKOUKI
yeah, everything is there and looks exactly like the drivers side
Old 01-29-2012, 07:13 PM   #4
Kingtal0n
Kingtal0n's Avatar
I dont know why it would have suddenly changed, but, if you decide to, you can remove the door panel and adjust the height of the window. There are two nuts that control how high the window can move before it stops. If you adjust it for the window to go slightly higher, it will push harder on the weather strip, and that may cure your issue.
Just be careful because you can go too high!
