Old 06-30-2016, 11:35 AM   #1
JDM king240
JDM king240's Avatar
JDM king240 is an unknown quantity at this point
SR Fully Built Sr20det and parts!!
** Please Read carefully ***
S13 Sr20det redtop -$3500
Bottom End:
*Eagle rods(new)
*Supertech forged pistons 9:1 / 87mm (new)
*Clevite rod bearings(new)
*Clevite main bearings(new)
*Greddy oil pan(used)
*S14 oil drain(new)
*Chrome pulleys(new)
*Grex oil relocation kit(used)/ greddyoil filter(new)
*Apexi headgasket(new)
*Circuit sports solid poly motor mounts(new)
*ARP Main studs
*GREX oil relocation kit
Top End:
*Full BC titanium retainers/valve springs(new)
*Stock cams(Cleaned/refreshed)
*Tomei rocker arm stoppers(new)
*chain and guide(new)
*Circuit sports billet aluminum side feed fuel rail(new) - $150
*Detchworks 810cc injectors(slightly used) - $350
*ARP Head studs
*NGK iridium spark plugs
*stock coil packs
Machine work:
*87mm bore
*The block was honed and decked.
*The original head was no longer any good so i picked up a new head which was fully cleaned decked.
*The crank was replaced with a new one that was balanced and polished.
*All seals and gaskets have been replaced with new ones.
*All machine work was professional done by Limitless Motorsports.
Turbo side:
*Garrett GT2876r with T3 housing (top Mount) - $1000
*CX racing Top mount T3/T4 turbo manifold with external castigate fitting $300
*Precision PW39 39mm waste gate(new) - $200
*All new hardware and gaskets
*I will not separate the block and the head, will be sold as a long block
*Items with prices labeled can be sold individually and if you buy more than 1 item I will discount the price.
*I can ship at buyers expense
Pictures: http://s346.photobucket.com/user/S14...r20det%20build
JDM king240 is offline   Reply With Quote
Old 06-30-2016, 12:07 PM   #2
sr20time
sr20time is an unknown quantity at this point
i would like the turbo lines... what exhaust manifold is that?
sr20time is offline   Reply With Quote
Old 07-02-2016, 04:23 AM   #3
JDM king240
cx racing exhaust manifold and if you want em you got them dm me
Old 07-02-2016, 07:51 AM   #4
Mofuhcka
Barrys World
Mofuhcka's Avatar
Mofuhcka is an unknown quantity at this point
I can vouch for this motor
Mofuhcka is offline   Reply With Quote
Old 07-02-2016, 10:26 AM   #5
mmmjesse
mmmjesse is an unknown quantity at this point
i think you have a typo on your turbo specs. from your pictures this looks like a gt2876r. for it to be the 2867 it would have to be a GTX and have the billet compressor wheel.
mmmjesse is offline   Reply With Quote
Old 07-02-2016, 11:16 AM   #6
JDM king240
Thanks for the catch, You are correct
Old 07-06-2016, 06:15 PM   #7
sr20time
payment sent for lines. and bump for you
Old 07-06-2016, 06:34 PM   #8
King.D247
King.D247 is an unknown quantity at this point
How much for long block ?
King.D247 is offline   Reply With Quote
Old 07-07-2016, 12:17 PM   #9
JDM king240
bump all inquiries replied to
Old 07-08-2016, 12:18 PM   #10
JDM king240
Friday bump
Old 03-28-2017, 12:47 PM   #11
djras1
djras1's Avatar
djras1 is an unknown quantity at this point
still have the head?
djras1 is offline   Reply With Quote
