Closed Thread
Old 09-02-2010, 04:45 PM   #1
alex.foo
alex.foo's Avatar
alex.foo is an unknown quantity at this point
man, im sad
well this is my first thread im hoping i get feedback
so i took my baby to get smogged
everything was going by fine....the smog tech even complimented me on my baby
till i got the results........i failed my emissions test by 4 f***ing points
so ima need my car...specially for this weekend
and i need to pass smog ASAP
i was wondering if there is anything besides an oil change that i could do
please help dudes.....
alex.foo is offline
Old 09-02-2010, 04:52 PM   #2
niteridaz503
niteridaz503's Avatar
niteridaz503 is an unknown quantity at this point
Can you provide more detailed info on numbers? i failed 3 times then passed hahaha i bet i can help.
Originally Posted by yetijeff View Post
Hes higher than giraffe pussy lolz
niteridaz503 is offline
Old 09-02-2010, 04:52 PM   #3
SoCalDrifter
SoCalDrifter's Avatar
SoCalDrifter is an unknown quantity at this point
run the highest octane gas around you and drive it around for like 30 min b4 u go to get it smogged
SoCalDrifter is offline
Old 09-02-2010, 04:57 PM   #4
Sam_Well.13
Sam_Well.13 is an unknown quantity at this point
you can seafoam it.... it helps clean the carbon build up in the motor an what-not...
Sam_Well.13 is offline
Old 09-02-2010, 04:57 PM   #5
alex.foo
alex.foo's Avatar
oh ok! cool
the numbers:
HC (PPM)
MAX MEAS
15 mph---------58-------------56
25 mph---------42-------------46
it says i passed the 15 mph test but not the 25 mph
HELP
alex.foo is offline
Old 09-02-2010, 05:01 PM   #6
murda-c
murda-c's Avatar
how old is your cat?
murda-c is offline
Old 09-02-2010, 05:02 PM   #7
alex.foo
alex.foo's Avatar
same as the car
alex.foo is offline
Old 09-02-2010, 05:23 PM   #8
niteridaz503
Seafoam works wonders for me lol If you do seafoam your car you should do a very minor tune up nothing major to aid you also do your oil change too with good oil
also switch up your fuel like SoCalDrifter said that helps too.
Old 09-02-2010, 05:37 PM   #9
alex.foo
alex.foo's Avatar
hey dude can u explain to me this seafoam method
im actually ready to head over to my kragen and pick up some things
thanks
alex.foo is offline
Old 09-02-2010, 05:58 PM   #10
[email protected]
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
just run 91, drive your car for like 15 min so its nice and hot, done.
R@ddy is offline
Old 09-02-2010, 06:14 PM   #11
alex.foo
alex.foo's Avatar
hey can u explain to me this seafoam thing
i want to try it out
alex.foo is offline
Old 09-02-2010, 06:16 PM   #12
JVD
JVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfection
it's never been covered before on this forum...
or google
JVD is offline
Old 09-02-2010, 06:21 PM   #13
alex.foo
alex.foo's Avatar
niteridaz503 seems to know what it is......
ey niteridaz if u can please let me know how u seafoam ur car
or what it means to seafoam the car
alex.foo is offline
Old 09-02-2010, 06:50 PM   #14
Sam_Well.13
seafoam is easy man..
grab a 3 spray can caps and divide the sea foam can in to 3...
*make sure car is at operating temp.
*locate your brake booster hose
*unplug it and plug it with your thumb
*then slowly get the sea foam in there. when your almost done.. pour all the seafoam in that 1 cap till motor stall
*pour the other cap in the crank casing and the other in gas tank.
let it sit for 15-20 minutes.
*start the car up (might have to give it some gas)
*keep a constant RPM 3000K at most. dont drive the car.
*alot of white smoke will come out.
*make sure you do this in a well ventilated garage. a fan may help also.
untill all the smoke is done. do you tune-up
spark plug, oil, fuel filter. and done.
Old 09-02-2010, 06:51 PM   #15
Sam_Well.13
i did this with all my 240's when i first buy them. and also did this to my dad's 300CE and C280. car came out running like a champ..
Old 09-02-2010, 07:04 PM   #16
repda916
repda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymore
be careful though. seafoam on old cars can actually do more damage as the carbon build up motors is what is keeping the motor strong.
repda916 is offline
Old 09-02-2010, 07:24 PM   #17
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
change your oil.
get fresh spark plugs.
run it for 30 mins beforehand.
profit.
brndck is offline
Old 09-02-2010, 07:25 PM   #18
alex.foo
alex.foo's Avatar
just like that i can ask for it at kragen?
alex.foo is offline
Old 09-02-2010, 07:44 PM   #19
240sxxs
240sxxs's Avatar
240sxxs is an unknown quantity at this point
seafoam sure.. that work...or run 3/4 of gas in ur gas tank and dump 2 denature alcohol into ur gas tank and drive it to the emission place quick before the gas dissolve the alcohol.. and dont floor it or go pass 2k rpm... it should pass like no other.....i done it to my other car and sr and vg ... ...i help no responsible for your motor..and this method only should be the last resource....
The pretty one Arn't free and the free one Arn't pretty
240sxxs is offline
Old 09-02-2010, 08:20 PM   #20
alex.foo
alex.foo's Avatar
i know huh?
i have a KA and i cant even pass smog with that, imagine an SR or RB
damn dude, i feel like trying the seafoam method
but i dont want to interrupt my engine and get less compression than i already am
u know?
hey do those carbon cleaners work?
alex.foo is offline
Old 09-02-2010, 08:20 PM   #21
Sam_Well.13
yea thats what ive been reading also.. carbon build up helps the motor keep its compression or what not and seal up bad gaskets that got damage over time.. luckyly i havent had a bad run with it.
all the cars ive sea-foamed are less than 150K
and yea you can ask at kragen or autozone..
Old 09-03-2010, 06:40 AM   #22
ThatGuy
Admin Asshole
ThatGuy's Avatar
All these techniques have been discussed, in great detail, prior to you starting this thread.
In the future I recommend you doing actual RESEARCH instead of just expecting everyone to spoon feed you answers.
ThatGuy is offline
Closed Thread
