Old 12-02-2008, 09:07 AM   #1
heavenboundkevin
heavenboundkevin's Avatar
heavenboundkevin is an unknown quantity at this point
Kicking up sand sound from front pass. side?
Anyone know what this is? It sounds just like when you drive over sand and it gets kicked up, but this sound occurs during everyday driving on paved roads, coming only from the front passenger side around where the wheel is. I actually havent been anywhere sandy or gravel"y" in quite some time. Then I heard this weird grind like noise coming from the same area. Any help is appreciated. Car is a 91 coupe. Bone stock.
heavenboundkevin is offline   Reply With Quote
Old 12-02-2008, 09:39 AM   #2
projectRDM
projectRDM's Avatar
Wheel bearing? Jack it up and feel for play in the bearing and listen for grinding or groaning as the wheel turns.
FORMERLY R240NA
Old 12-03-2008, 08:14 PM   #3
4x4le
4x4le's Avatar
4x4le is an unknown quantity at this point
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
maybe a rough spot on a rotar dragging?
4x4le is offline   Reply With Quote
Old 12-16-2008, 09:11 PM   #4
alzahakar
alzahakar's Avatar
alzahakar has a little shameless behavior in the past
As stupid as this may sound, make sure your caliper isn't missing a bolt and rubbing against the inside of the rim. When I bought my first S13, i heard that noise all the way from the seller's house to my place (only 1/2 mile, thank god) and sure enough, I got it home, took the passenger side tire off and the caliper was missing a retaining bolt.
alzahakar is offline   Reply With Quote
