Old 04-02-2013, 06:07 PM   #1
Anhell_ito
Anhell_ito is an unknown quantity at this point
HELP! Adjusted IACV the wrong way.
Ive searched around and couldnt really find much on this specifically. finally finishing up my s20det swap. is an s13 type x with j4 ecu going into an s14. i decided to adjust the idle screw without going into idle adjust mode and as soon as i gave throttle the car died. tried starting it up and noticed my fuel pump is not priming. could these 2 be related in anyway? i hard wired the pump and its working fine. my ecu isnt giving any power to the relay. and the car started perfectly the past 2 days. any one out there that would be able to shine some light?
Anhell_ito is offline   Reply With Quote
Old 04-02-2013, 09:53 PM   #2
Anhell_ito
anyone?
Old 04-04-2013, 06:16 AM   #3
KoukiMonsta
KoukiMonsta's Avatar
Turning the IACV screw will not affect power to fuel
Pump relay.
@UpshiftEngineering
Old 04-04-2013, 07:24 AM   #4
korito727
korito727's Avatar
korito727 is an unknown quantity at this point
^ agreed they don't affect each other.
Oddly enough tho I have had a couple friends have issues with the fuel pump not priming with s13 sr's into s14's. I don't have an answer for you but a search and a peak thru the wiring diagrams for your fuel system should lead you in the right direction.
THRYx8SVN
korito727 is offline   Reply With Quote
