E85/Fully Built Ka/95 240sx
Currently Tuned on e85
1995 Nissan 240SX SE 180k on the chassis 5K MILES ON THE MOTOR/TURBO SETUP..very fresh Power windows(needs passenger window motor) Power Locks, Power Mirrors, Needs Power Steering Pump Sunroof was deleted w/ a One-off delete panel (needs repair as seen in pic)expensive piece Pavels Racing Engines sourced a great conditioned head, port matched, cleaned, machined, and assembled my shortblock. TF-Works, had the head COPPER O-ringed, and installed everything from there, including the turbo kit. Engine: KA24DE 16 Valve DOHC Wiseco 9:1 Forged Pistons bored .040 over Eagle Rods All new bottom end bearings ARP Main Studs ARP Rod Bolts ARP Headstuds Cometic Headgasket OEM Timing Chain Kit OEM Front Oil Cover with Oil Pump OEM Full Gasket Kit Complete S13 Head/Cams(port matched) (240/248 Cams) S13 Valve Cover -Modded, removed and replaced internal baffling -CMWerks powercoated -Modded by TF-Works for a Custom Oil Catch Can Kit -(-10an) Earls fittings and SS Lines S14 Intake Manifold Oil Cooling: Greddy Sandwich Plate w/ 1/8th gauge port -10 Fittings and SS Lines -Setrab Series 6/16row Oil Cooler -Custom TF-Works Oil Cooler Mount Xcessive SR Oil Pan Adapter Moroso Aluminum Baffled SR Oil Pan Turbo Kit: ISR Performace V2 Turbular Exhaust Turbo Manifold Garrett GT2871r .86 -wastegate was professionally ported out by TF-Works -Stainless Steel Water lines and Oil Lines/Fittings Stance GT Turbo Reclocking Kit S13 SR Intercooler Kit HKS SSQV BOV 3 inch Downpipe w/ Flex Section 3 inch Mild Steel Custom Exhaust (looks like a straight pipe) Vibrant Race Muffler(welded in-line) Fuel: ID1700x Injectors Radium Top Feed fuel rail Fuel Lab Pressure regulator 818 Series In-Line Fuel Filter Walbro 255 Pump E85 Igntition: NGK BKR7E Plugs Magnecore 10mm R-100 Race Wires OEM Distributor Cap/Rotor Cooling: Mishimoto Radiator Silicone Radiator Hoses Water Overflow Tank Drivetrain: S13 Transmission Nismo Pivot Ball OEM Slave Cylinder Competition Clutch Stage 4 Resurfeced OEM Flywheel Driveshaft Shop 1piece Steel Driveshaft S15 Spec R HLSD w/ output Shafts AVID Solid Motor Mounts Peak Performace Race Transmission Mount Redline MT-90 Fluid-Trans Royal Purple 75/140-Diff Brakes: Z32 Calipers SP Slotted/Vented Rotors OEM rear Calipers Z32 17/16th BMC Suspension: STANCE GR+(9/7k)springs Peak Performace Front Tension Rods Peak Performace Outer Tie Rods C.Sports Inner Tie Rods C.Sports RUCA C.Sports Rear Toe Rods STANCE Rear Subrame Bushing Collar Inserts OEM SE Rear Sway Bar Whiteline Front Sway Bar Whiteline Adjustable Sway Bar Endlinks Wheels: Enkei RPF1 17x9.5 +18 17x10 +18 WILL NOT COME WITH WORK EQUIPS AS SEEN IN PICS Exterior: Version Select BodyKit Orgin Front 20mm Over Fenders Orgin Rear Type ll 50mm Over Fenders Seibon Carbon Fiber Hood (Damaged isnt on car) Aero-catch Locking Hood Pins(broken for there hood isnt on) Front Crash Bar Interior: NRG Seats NRG Short Hub NRG 2.5 Quick Release KEY!S Racing Steering Wheel Nismo Shift Knob Electronics: Ultra Slim Race Battery NRK AFX Powerdex Wideband STRi Water Temp STRi Oil Temp STRi Oil Pressure STRi Boost Pressure Alarm w/Keyless Entry AEM V1 ECU Tuned by iLL Garage Tuned 430rwhp~ Sure im missing a couple things have all paper work for motor over 10k in receipts parts/labor Windshield is cracked will replace it. Dont mind keeping the car not in rush to sell 708 7three7 9one 88 12.5k$ Doesnt let me post pic https://chicago.craigslist.org/chc/p...137685722.html |
