12-18-2014, 07:28 PM | #61 |
Wow, I should have given you my first kouki. You needed a tetanus shot just to sit in it.
02-14-2015, 02:26 AM | #65 |
Change the front wall
The one side of chassis rails are pushed inside, so I fixed it. And the new front is on the right place. Last edited by TSSS22; 06-08-2017 at 08:37 AM.. |
02-24-2015, 02:23 PM | #66 |
New fiberglass +25mm front fenders, new seats and oil catch tank.
The servo oil tank is in the new place near to clutch cylinder. Last edited by TSSS22; 07-14-2015 at 03:22 PM.. |
04-01-2015, 12:14 PM | #70 |
Great work as usual!!!!
S15 SR20DET Powered, Kouki S14 http://zilvia.net/f/showthread.php?t=578575 |
04-23-2015, 02:20 AM | #71 |
Thanks
Fitted oil catch tank and relocated screen washer reservoir Mounted custom hood springs from VW Polo Apexi style exhaust New stainless steel tubes for FMIC piping, I am using stainless steel because I have only DC TIG welder. Welding aluminium with this is not impossible but is more difficult especially with scratch start. Purple lug nuts from United States FMIC and other things |
07-14-2015, 03:20 PM | #73 |
Ok so there is the pictures of actual progress and works.
Rear inner fenders... Bottom of the body is finished Suspension - ON. Wheels - ON. Rear +50mm(maybe more) Fenders - In Progress. |
12-31-2015, 08:21 AM | #77 |
Hi I am back with new pictures
Last pic on these wheels now Fitting the sideskirts I found lot of rust on the door mounting points... Last weldings in enginebay I cut side skirts to two parts for better manipulation with front fender. Now I can take down the front fenders with this small part of sideskirt without drilling down the rivets. Black base coat in enginebay The real petrolheads have christmastreeholder like this |
02-29-2016, 10:06 AM | #79 |
After spending a lot of hours working on enginebay, is ready to paint
I need output shafts for my vlsd to finish it. The interior is ready for paint too Yesterday I got my kouki´s Brand new dust covers from KTS japan |
10-05-2016, 02:50 PM | #83 |
Hi, yes of course, sorry for late update. Freshly I have Instagram https://www.instagram.com/nissan_200sx_rs13/
and you can follow the build on facebook too https://www.facebook.com/szabolcs.szamel Turning to the build, the works are going very slow but its not new. I continued the process in enginebay. I used lot of putty and sprayputty for clean finish.... I think I found the best color for enginebay, black base and some layers of purple custom painting pearls. The right side of testline. I found the really good condition dashboard and prepared the hood underside for painting, basecoat with seam sealer. |
06-08-2017, 05:30 AM | #84 |
Hi, I am back with new pics and infos about the project. Its not dead, just I dont have time to write the new post... With my girlfriend we buy new dailycar: BMW E46 323i sedan, yea its not only my decision. She love the cars also, and She like to drive something nice with correct power specs and I like to buy RWD so this is the result. I worked on car, new polyurethane front bushings, changed steering rack - the old is leaking, exhaust system from 330i - need to little weld for the best fit, and modded muffler (sounds really good ) and some little mods like angeleyes, autodimming mirror, bluetoothmod for oem HU.
Ok, so whats up with the s13 you ask... At the moment the car is in the paintshop But I have a lot of work with her before current pos. I finished the gasdoor repaired all fiberglass body parts because they are terrible there is some pics testing the exhaust position... and I bought brake calpiers from 300zx made bashbar and use foam for best fitment of the rear bumper and then put everything together Chill out! I bougth spacers: 20mmfront and 60mm rear And one spy photo BTW I fixed all of the old links for photos Last edited by TSSS22; 06-08-2017 at 11:51 PM.. |
