04-03-2013, 10:50 AM | #1 |
**SG Brake Line Relocation Kit S13/S14**
Ace Up Motorsports is pleased to introduce the SG D.O.T approved Brake Line Relocation kit for The S13/S14 Chassis. MUST USE S13/Z32 STYLE MASTER CYLINDER. The Kit is used to eliminate the clutter of hard lines that run across the firewall which everyone knows is ugly. When ordering you have the option of adding a matching clutch line as well. Professional Installation is Required. Comes with 3 Banjo Bolts and 6 Crush washers. Available In Gray or Blue
Price $200 Shipped or $255 with Clutch Line Visit www.aceupmotorsports.com/SGbrakelinekit
www.aceupmotorsports.com |
04-03-2013, 10:52 AM | #2 |
Does this give any spongy feel to the breaks? I like the idea and if not ill be ordering a set in the near future and the old lines are rounded off. And of course In the way.
04-03-2013, 11:48 AM | #4 |
04-03-2013, 05:30 PM | #5 |
We did not feel a difference in pedal pressure on any of our test cars. The lines are simply ran from the master down to the subframe and up on the other side. We never designed a set way to mount it as everyones setup is different so it can be secured however the owner sees fit. The lines also allow you to run a Pathfinder master cylinder for guys who are running bigger top mount turbos and want the lines to be further away from the exhaust housing/downpipe. There are a couple board members that already have them and I would love for them to chip their ideas and thoughts!
04-03-2013, 07:04 PM | #6 |
Wow looks awesome! I think I'm going to have to get one soon. Would definitely complete the new tucked look in my engine bay, no wires anywhere, even running along wheel wells.
04-04-2013, 05:02 PM | #8 |
They Are Tested At 4,000Psi And Rated At 3,000. Everything Is Assembled Here In Arizona
05-16-2013, 09:56 AM | #9 |
I noticed on your website someone mentioned the banjo bolts were a tad long and had to be replaced.. Has this issue been addressed? If so... I wants
05-22-2013, 08:43 AM | #14 | |
Sent from my iPhone using Tapatalk 2
05-31-2013, 11:40 PM | #16 |
Looks like it just goes downward and zip linked with the top part rmember and the back on the other part is just pretty much fascinating.
limo services | sydney limousine | sydney limousine service Last edited by EmporioJason; 10-27-2015 at 04:46 AM.. |
06-02-2013, 08:13 PM | #19 |
what are the lengths of the lines?
or can you name them in order longest to shortest/shortest to longest. aka what is the bleeding procedure
formerly known as "hotboiblaze" ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
06-11-2013, 09:34 AM | #20 |
Question website states that these must be used with s13 master cyl. Would it not be the same for us guys running 300zx master cyl. The OEM lines bolt right up, why won't these?
07-02-2013, 10:02 PM | #23 |
So this works on z32 master cylinder usmd and jdm ?
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
