Old 12-26-2019, 05:11 PM   #1
NashT
NashT has made poor choicesNashT has made poor choicesNashT has made poor choicesNashT has made poor choicesNashT has made poor choicesNashT has made poor choices
Toyota 5.7L in S-Chassis?
Hey guys i tried googling with no results.
Just wondering if anyone has seen someone do a toyota 5.7L swap in a 240?
Thats a badass motor with an abundance of hp and torque, i love it in my truck and cant imagine how it would feel in a 240
Thanks
NashT is offline   Reply With Quote
Old 12-26-2019, 05:13 PM   #2
S14rebuild
For the price it takes to swap it...there are other viable options that would be cheaper, less custom fab work/wiring. Not to mention aftermarket support.
But if u chose to ignore all tee above, feel free to go for it, be a first and diffrent from others. Just start a build thread so we can all see the progress and effort put forth
Old 12-27-2019, 02:56 PM   #3
lewisfk
lewisfk's Avatar
lewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond repute
The 1uz Toyota engine swap is not so complicated, try using parts from that swap. I never compared the blocks to see where the engine mounts would line up. Just shooting for the hip, good luck!
lewisfk is offline   Reply With Quote
Old 12-27-2019, 04:23 PM   #4
5280VertDET
5280VertDET's Avatar
Engine height is going to be your problem, much like the Nissan 5.6 and the LS truck intakes. Tall intakes and low sumps. Unlike the LS, the 5.6 and 5.7 have no aftermarket easy & cheap swap components.
Old 12-27-2019, 08:53 PM   #5
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
Not to mention being flimsy garbage.
If you want to put something dumb and heavy that doesn't fit, try an older gm or mopar v8.
mechanicalmoron is offline   Reply With Quote
Old 12-30-2019, 12:57 PM   #6
jedi03
buddy did one...was very heavy and costly but worked! we did discuss power output vs LS and LS seemed like better option longterm...
Old 12-30-2019, 02:50 PM   #7
NashT
You did a toyo 5.7 swap or just an old domestic v8 swap?
The 5.7 is a badass engine that likes high and constant revs unlike the LS.
Would it be a hassle and require some fab, definitely, but im not trying to run what everyone else is. Was just curious if anyone has done the swap or seen one in an S-Chassis. I saw a supra that a dude had stuffed the toyo 5.7 in, where I got the idea from
I hadn't thought about the height though, thats a good point. And i could be wrong, but i thought it was an aluminum block- will google
Old 12-30-2019, 02:54 PM   #8
NashT
5.7 service weight is 489 lbs
LS1 service weight 430 lbs
The HP & Torque difference alone would make up for the weight difference
Old 12-31-2019, 09:01 AM   #9
lewisfk
lewisfk's Avatar
^^ Do you bro! I'm trying to secure a g35 coupe or 350z chassis to swap in sr20det vvl. I'm not the first to do the swap and i will not be the last.
Old 12-31-2019, 05:52 PM   #10
mechanicalmoron
The HP and torque difference is that the toyota engine is stuck at what it makes, while the ls will make any amount of power you want, for cheaper.
They have a heavy knock from the factory.
That's not how weight works. You can't make up for it.
Little Toyota V motors could be more interesting.
Old 01-01-2020, 11:27 AM   #11
silviaks2nr
silviaks2nr's Avatar
I would never consider it and I have a tundra with this engine, it's just so massive and there's really no aftermarket for it.
'98 240sx 5spd
Old 01-02-2020, 08:51 AM   #12
jedi03
we did both...the ls was preferable due to aftermarket support
Old 01-02-2020, 10:26 AM   #13
lewisfk
lewisfk's Avatar
There is aftermarket support but not as robust as the sr/rb/2jz etc. Lot of my oil field buddies here in Texas love their Tundra trucks and love supercharging. They have no problems finding parts, I don't understand why people are giving him/her so much shit. Pitch in with some knowledge and support and let's see this beast rip it up!
https://www.realstreetperformance.co...-set-of-8.html
https://www.trdusa.com/trd-engines-b...the-build.html
Yotashop.com
