Old 10-10-2013, 07:11 PM   #5881
PoorMans180SX
PoorMans180SX's Avatar
Old vs. new.
Together:
Old 10-11-2013, 02:24 AM   #5882
[email protected]
robbie@tdp.ie is an unknown quantity at this point
Old vs. new.
Together:
Put t on the car and then take the photos.. LOL
robbie@tdp.ie is offline   Reply With Quote
Old 10-11-2013, 01:33 PM   #5883
808drft
808drft is an unknown quantity at this point
I have a vision here but I'm not sure if what I've thought up will work. Perhaps you guys can point me in the right direction.
I'm building a car with a tube frame front and I want to use S-chassis suspension because of the availability of parts. However,
I also really want a double wishbone set up in front, so here is what I've come up with:
I'll use an s-chassis subframe, rack, and LCAs, and then machine a metal puck which will be welded into a short cut off part of
the strut, holding a ball joint and attaching to the upper control arm which I'll fabricate. Sort of like the image below:
The mca s13 in Australia is using a double wishbone front suspension using 240sx knuckles
Nerd's Eye View: The MCA Suspensions "Hammerhead" Silvia S13
808drft is offline   Reply With Quote
Old 10-11-2013, 05:46 PM   #5884
PoorMans180SX
Ride Height:
Control arm angle:
EDIT: Old setup when the car was higher and picture is slightly angled.
Old 10-11-2013, 07:02 PM   #5885
dudermagee
dudermagee's Avatar
Ride Height:
Control arm angle:
epic stuff right there
what about the rear?
Originally Posted by DC Dan MAX USA View Post
Don't wuss out on me.
dudermagee is offline   Reply With Quote
Old 10-11-2013, 10:16 PM   #5886
PoorMans180SX
Rear is basically stock with subframe risers unfortunately . It'll be a while until I can afford either the Wisefab rear or the new TDP kit that's in development.
I should probably include this. Take in line with the strut tower, no cheater ahead of the car shots . This is with the strut inside the PCD of the strut tower and around -4.7* of camber on each side.
Old 10-13-2013, 11:16 AM   #5887
Silvi
Silvi is an unknown quantity at this point
Are you guys using lock stops on extended LCAs and big angle knuckles?
how bad is not use them? im not sure if my tie rod is close enough to hit the LCA
Silvi is offline   Reply With Quote
Old 10-17-2013, 09:30 AM   #5888
mikerbike
mikerbike is an unknown quantity at this point
Remove the lock stop and notch the control arm. You'll need to move the inner tie rod forward too. Easiest way is to buy offset rack spacers. But the best way is to modify the subframe so the rack sits further forward.
mikerbike is offline   Reply With Quote
Old 10-17-2013, 03:57 PM   #5889
Motary
Motary's Avatar
Motary is making a name for him/her selfMotary is making a name for him/her self
Send a message via MSN to Motary
lul ^ dat bumpsteer and strength
Motary is offline   Reply With Quote
Old 10-17-2013, 04:56 PM   #5890
rbs14kouki
rbs14kouki's Avatar
Zak Pole new r33 set-up
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
Old 10-17-2013, 09:51 PM   #5891
Silvi
The steering rack is already forwarded by 25mm.
about notching the LCA, i'm afraid that the notched LCA wouldn't be strong enough
Old 10-19-2013, 06:55 AM   #5892
Black R
Black R's Avatar
Black R is an unknown quantity at this point
Originally Posted by thefro526 View Post
Please excuse me if this has already been discussed, but anyone know anything about these:
Apparently, they're made by Manatee Racing, and don't seem to be all 'that' common. (although, there was a set for sale on YAJ recently)
The Front and Rear LCA's are somewhat standard and/or straight forward, but the Rear Upper Control arm (bottom right) seems to be really different. I've been trying to wrap my head around what exactly it is, or does, and the only explanation I can come up with is that it's a one piece version of our 'upper A-arm' - one piece being that it combines the Traction Rod and RUCA. (IIRC, Dentsport's S13 has a similar upper arm)
What's the benefit to this, if any?
I wonder what's the cost association?
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers
Black R is offline   Reply With Quote
Old 10-19-2013, 07:24 AM   #5893
Black R
Black R's Avatar
Originally Posted by GKTECH View Post
time for some track testing. The current Australian dollar is good for you guys. The intro price is going to be $199 AUD including our sales tax which is $181AUD excluding our tax = $162USD + delivery.
40mm roll centre correction and a little over 60 degrees of bolt on steering lock.
I want to see a car with these!
Are they out yet?
Old 10-20-2013, 03:05 AM   #5894
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
do you have a picture of the clearance between the wheel/tire and frame at full lock?
REVIEW
killer240 is offline   Reply With Quote
Old 10-20-2013, 11:43 AM   #5895
PoorMans180SX
Here you are sir:
The inner rim is hitting the LCA in this pic, even though it doesn't look like it.
Also, here's a picture of my friend Kurtiss's car, he has the TDP kit with the struts relocated farther forward than mine. It pulls more angle this way.
Old 10-22-2013, 02:49 AM   #5896
killer240
killer240's Avatar
Trader Rating: (24)
^^^^thank you
I'm debating wether to get this kit, the price is what's bothering me.
REVIEW
Old 10-22-2013, 10:18 AM   #5897
PoorMans180SX
^^^^thank you
Yeah, it is definitely expensive. I'll say again though, the adjust-ability is phenomenal. I can make this a wisefab low caster setup, and with a few minutes and an alignment turn it into a normal modified knuckle style setup. A few more minutes and it's set up with higher ackerman for a road course. The roll center correction also kills most everything else on the market.
Don't do it if you're like me and now struggling to get the car together because you bought an angle kit though, hah.
Old 10-22-2013, 08:56 PM   #5898
MiamiZ33
MiamiZ33 is an unknown quantity at this point
PoorMans180sx, what did you do with the DW stuff?
If somebody has Geomasters laying around they'd lend me, I'd pay to borrow them. I want to CAD them up and make my own.
MiamiZ33 is offline   Reply With Quote
Old 10-22-2013, 11:16 PM   #5899
PoorMans180SX
I never had any Driftworks stuff, I had always wanted to buy it when it was the only drop knuckle kit on the market, but I never got a chance.
Old 10-24-2013, 08:34 AM   #5900
Motary
Motary's Avatar
That is quite a lot of clearence, are you using overdenders to cover the wheels? My arm is about 25mm longer than stock and I have poke
Old 10-24-2013, 09:03 AM   #5901
thefro526
thefro526's Avatar
Could be totally wrong here, but it looks like he's got 20/25mm Over fenders with a relatively narrow wheel, maybe an 17x8.75" (I think those wheels come in that size.)
thefro526 is offline   Reply With Quote
Old 10-24-2013, 10:29 AM   #5902
PoorMans180SX
These arms at their shortest are 35-40mm longer than an S13 arm.
I'm using "40mm" wide fenders (I don't have stock ones so I can't compare), and an 18x8.75+20 wheel with a 215/35/18 tire. The fenders are currently riding on the tire, and I might just have to get flares or a smaller tire to make it functional.
I am pulling -5* of camber in the front with the knuckle adjusted to the maximum positive camber at this ride height. This is because I have the strut inside the PCD of the tower, and the knuckle hits the lower part of the coilover.
The tire also scrubs at the top of the wheel well at lock (trailing wheel), I'm not sure what combo of hammering, cutting, or raising the car will make this functional yet. If it comes down to raising it, I don't want to raise it much, as my whole point in buying this kit was to make a low car function as best it can.
I'd really like to get some 17x8.25's for the front with a 215/40/17.
Not sure when this is going to be on the road for some actual testing, hopefully before the close of the year.
Old 10-25-2013, 07:21 PM   #5903
Black R
Black R's Avatar
Wait, what?
So if you had lower offset wheels, it wouldn't hit the LCA?
And then you could dial in even more angle?
What clearancing have you done to the inside of the wheelwells?
Mini tubs?
Ground off and welded the seams?
Just straight cut shit out?
Old 10-25-2013, 10:06 PM   #5904
PoorMans180SX
Originally Posted by Black R View Post
Wait, what?
Mini tubs?
The trailing wheel hits the top of the wheel well at full lock. This is the only clearance issue I have at this point. I may just cut the wheel wells out for clearance. The only clearance work I have done is hammer the seems in the well as you can see above, as well as the classic on top of the well.
I could dial in more angle two ways, reduce the caster, or get thinner wheels. Lower offset won't really work unless I get fender flares, the wheels are already touching the fenders. I want to get some 17x8.25 of these same wheels for the front, but they don't really make a shorter tire than the one I have on it, so I'll have to either raise it or cut the wells out/tub it.
Old 10-26-2013, 02:43 AM   #5905
OgSilviaSkywalker
OgSilviaSkywalker's Avatar
OgSilviaSkywalker is an unknown quantity at this point
i need those gktech knuckle attachments so bad!!!!!
OgSilviaSkywalker is offline   Reply With Quote
Old 10-26-2013, 02:44 AM   #5906
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
Feedback Score: 115 reviews
Anyone else read about the gktech knuckles breaking from overcentering?
Sent from my SAMSUNG-SGH-I527 using Tapatalk
Old 10-26-2013, 03:44 AM   #5907
Motary
Motary's Avatar
Poorman, how is the clearence from brake line bracket at the chassis side? I had to move mine via one bolt hole
Old 10-26-2013, 08:54 AM   #5908
PoorMans180SX
The thing I read the guy had moved the steering arm up and out of the slot it goes in. I'm not sure why you would do that...
And I guess they are discontinuing the "Extreme" steering arms, apparently a lot of people are having binding issues (aka set up the car wrong), and I'm sure GKtech wants to cover it's back.
GKtech put a press release on their facebook:
https://www.facebook.com/photo.php?f...type=1&theater
Oh yeah. It rubbed the bracket pretty bad. I have stainless lines from the master to the caliper to install, I'm not sure how that'll turn out.
Old 10-28-2013, 11:35 PM   #5909
OgSilviaSkywalker
I need extended ball joints for my flcas anyone know where to get some with about an inch if not more of roll center corroection
Old 10-28-2013, 11:54 PM   #5910
PoorMans180SX
Moonface makes ones with up to 15mm of correction I believe, you really can't go much past 20mm or it starts hitting your rotor. It also increases ackerman substantially.
Why do you need extended ball joints specifically? A much better solution is PSM's forged knuckle, or their Pro-grip knuckle if you're not into faster steering and low ackerman.
