Old 07-15-2008, 02:23 PM   #1
gorillam
gorillam is an unknown quantity at this point
idle problem sr20
I just finished my sr20 swap and double/tripple checked everything before taking it for a drive.
I am having a little bit of a problem with the idle, it hovers around 600rpm. and if i blip the throttle at all it will struggle and dip down/stall.
But it will idle well at 600 if i slowly nurse it down.
Suggestions on where to start?
gorillam is offline   Reply With Quote
Old 07-15-2008, 02:27 PM   #2
2-4-0
2-4-0's Avatar
2-4-0 has a spectacular aura about2-4-0 has a spectacular aura about2-4-0 has a spectacular aura about2-4-0 has a spectacular aura about2-4-0 has a spectacular aura about2-4-0 has a spectacular aura about
I'd start by doing the simple things first. Pressure Test it to see if you got any vacuum leaks. I've seen the weirdest things happen as a result of a vacuum leak
2-4-0 is offline   Reply With Quote
Old 07-15-2008, 02:58 PM   #3
gorillam
will do that, i think you are right it seems like it's a lean stall when the idle drops.
how's the weather in bc?
